Thread: Calcium hardness and vinyl liners
    I just took a water sample to the pool store so that I could use the results to improve my test color interpretation skills. The store measured my calcium hardness at 150 and recommended I add hardener. As I had learned on this wonderful site, I replied that since I have an above ground pool with a vinyl liner this was not an issue and I was happy with the 150 level. The answer to this was that the ideal calcium hardness doesn't entirely have to do with the pool surface, it's about what the water "needs". The salesperson said that the water needs calcium and if it doesn't have enough it will acquire it, suggesting that the water would leech it from the swimmers. I actually had to hold back a laugh. I wish at the time it had occurred to me to point out that to protect her bones perhaps she should never take another shower.
    So my question... Am I understandig this site correctly, there is no need to tend calcium hardness in vinyl pools? Is there any consideration beyond pool surface that applies to maintaining calcium hardness?
    As always, thanks for all the insight!
    Therese
    Above ground 24' 13,500gal
    TH 150
    FC 5
    pH 7.8
    TA 80 --> working on it with pool calculator
    CYA 50
    13,500 GAL half buried Doughboy AG Vinyl, 24' Round, DE filter
    22,548
    Re: Calcium hardness and vinyl liners
    In a vinyl pool you don't have to worry about low CH only high. The only reason to worry about it would be if you had a piece of equipment that the warranty hinged on the CH being maintained at some level.
    Yep, what Bama Rambler said.
    SinistrV6's Avatar
    Sep 2008
    Mississippi Gulf Coast
    111
    I, too, have ignored my "0" CH readings. My neighbor was taking her pool water to be sampled (I do my own sampling) and offered to take mine with her. I was curious as to how my results would compare and sent the sample with her. None of the results or recommendations surprised me but they suggested adding 80# of Calcium Chloride Flake to raise my CH to their recommended 174-350ppm range. When I told my neighbor that CH isn't a necessity in a vinyl pool, she said it helps to stabilize the other chemicals and has helped her keep her pool looking good.
    Any thoughts on this? BS? Fact? Fiction? Old wive's tale?
    42X16X24 True-L vinyl lined IG pool
    30,500 gallons
    Pool Pilot Digital SWG
    Sand filter
    Mar 2007
    San Rafael, CA USA
    12,082
    CH does not stabilize other chemicals and is not needed to make a pool look good. Too low a CH can have a pool have more foaming, but usually it's a spa where this is an issue since there is far more aeration. Around 120-150 ppm CH helps to eliminate foaming in a spa, but is not usually needed in a pool.
    Calcium is only needed in a pool or spa when one is trying to saturate the water with calcium carbonate -- that is, adjusting pH, TA, CH (and temp and CYA) to have a zero saturation index -- for the purpose of preventing calcium carbonate from dissolving from plaster surfaces and grout between tile. If there is no calcium carbonate in a surface exposed to the water, then there is no need for such calcium carbonate saturation. It's as simple as that.
