Thread: shocking and the leaves i can't see
    Is it even possible to get the water clear enough to see the bottom if I know there are leaves down there? I've cleaned up what I can with a leaf gulper and rake but I know there are more---I just can't see them to get to them!
    Rhonda
    NW Tennessee
    24' Round AGP
    13,500 gallons
    1.5 hp Pentair pump w/ sand filter
    From swamp to sparkly with BBB!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: shocking and the leaves i can't see
    Welcome to TFP.
    Be persistent and get whatever you possibly can with the leaf rake. They will continue to consume your chlorine.
    Thanks! Here's what I've got so far:
    pH: 7.8
    TA: 110
    FC: more than 5ppm (see below)
    TC: ?
    CH: ?
    CYA: 50ppm
    The test kit I'm using doesn't measure over 5ppm FC so I don't know exactly what it is. Same with Total Chlorine and Calcium Hardness. Since yesterday morning I've put a total of six (6) 182 oz. bottles of 6% bleach in the pool. It's been a little over an hour since I raked the leaves and added another bottle of bleach, and I see a big difference just since yesterday in the water color. I'm off for more bleach. Any recommendations?
    Rhonda
    NW Tennessee
    24' Round AGP
    13,500 gallons
    SW Indiana
    9,199
    Dilute your pool water sample with 3 parts distilled water and then test the mixture. Multiply your reading by 4 and you have an approximation of your chlorine level.
