Results 1 to 8 of 8
Thread: Is this really it ?????
    May 2009
    Ontario, Canada
    84
    I feel like something really bad is about to happen. This is my first opening since we put the pool in last year. Things seem to have gone too perfect.
    In April I stuck my hand in the pool, under the cover, and took a sample, chlorine was still very high. <4 I stopped counting because I didn't want to waste my drops.
    Monday we pulled the disgusting cover off. barf...
    Underneath my water was crystal clear, but I had to add 2 feet of water. Took forever, especially when we realized we forgot to put the plugs back in the filter and pump...duh.
    Tuesday am, I realize I forgot to order more fas-dpd drops...(on order), so I don't want to waste them and I throw in, I would say, 3L of last year's leftover chlorine in, so hubby can go refill the canisters.
    Tuesday noon I perform first test on my water.
    FC 8
    CC >.5
    TA 200 (started the MA/aeration cycle today)
    CYA below 30 (added cya sock)
    PH 7.5
    This morning:
    FC 5.5
    CC barely anything to turn clear.
    Everything's been vaccuumed (mostly junk from my solar cover, left out all winter)
    MA went in this morning and PH is currently at 7.2-7.3
    Temp is 73 degrees
    Can the kids jump in now? (I think the answer is yes, but sometimes need my hand held)
    21' 54" Round AG, 10K gallons,1HP 2 speed pump, Sand filter 200lb
    Have had a sparkling BBB pool all summer....
    jmack1159's Avatar
    Apr 2010
    Arkansas
    45
    Re: Is this really it ?????
    Sounds like it is time to go for a swim!
    24' Above Ground installed March, 2010
    22 Sand Filter With Zeolite
    1.5 HP Motor Pump
    Successfully using the BBB Method!
    pool-school
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Was that an overnight Fc loss or during the day loss? If it was overnight, your answer is no. See Pool school overnight guidelines below:
    To perform the overnight FC loss test:
    If you have an SWG, tablet chlorinator, or other chlorine feeder, shut it off completely.
    After the sun goes down, and at least 30 minutes after your last chemical addition of the day, test your water for FC using the FAS-DPD test.
    Record that result. Do not put any more chlorine in your pool.
    The next morning, as early as practical and definitely before there is any direct sunlight on the pool, perform the FAS-DPD FC test again and record the results.
    If your FC level remained the same, or went down by 1.0 or less, the water is clean. There isn't any living algae or other organic contamination in the pool.
    If you lost more than 1.0 ppm of FC, then there is something in the water that needs to be removed and you should shock, or continue shocking, the pool.
    So if your 2.5 loss was during the night you need to shock. Note- 2.5 for during the day is fine but you should do the overnight to be sure. I just reread and saw your test was at noon. Chances are it is ok, but I would wait til tomorrow when you know for sure.
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Quote Originally Posted by aqualicious
    Temp is 73 degrees
    Only a Canadian would think about swimming in 73 degree water
    I say swim if they can stand the blue lips!
    Butterfly's Avatar
    South Carolina
    10,045
    Here's another "jump in" if you can stand that freezing water
    You're done SLAMing when:
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Quote Originally Posted by JohnT
    Temp is 73 degrees
    Oh John..We (kiddo and I) were in at 73..as long as the air temp is warm, it's all good..
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    May 2009
    Ontario, Canada
    84
    Yeah...well it's 30 something degrees here and the pool got up to a balmy 77!!!!! I guess I was shocked at the 73 because yesterday when we took the cover off it was 64.
    Last year we were happy if the pool reached 75, the weather sucked so bad.
    We, canadians were in the pool all day! EH! My son is still in there. I can't get him out.
    Hubby is greek though. He won't set toe in there until it's 94. He only went in twice last year.
    P.s. whoozer, yes that was a whole afternoon and evening with full sun exposure chlorine loss.
    Jun 2007
    New Jersey
    653
    You guys are unbelievable. Mine hit 73°F today and I was loving it. We also had record highs in the area of 91° to 93°. I like to cool off when I get in the pool, not stew.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
