Thread: ??s about moving sand filter
    esim13's Avatar
    Oct 2009
    Denham Springs, Louisiana
    320
    I will soon be moving my sand filter and pump to it's new location. My questions are these...
    On moving the sand filter, do I just drain the water out, use a hand truck and whirl it away to it's new location? What do I have to be careful of? We're going on 3rd summer with current sand so I shouldn't have to replace it, right?
    I only have 2 lines, one for return, one for suction. Should I put a Jandy valve on both lines while I'm replumbing?
    Is there anything else I should do while I'm taking it all apart?
    10,408 gallon, 21' round, 52 in' deep AG, half in ground
    Artesian Clear Master Plus Sand Filter, Artesian Turbo King 2 hp pump, installed June 08
    GEAUX TIGERS!
    Pics taken 2012
    http://i941.photobucket.com/albums/ad25 ... CN0606.jpg
    http://i941.photobucket.com/albums/ad25 ... CN0607.jpg
    jmack1159's Avatar
    Apr 2010
    Arkansas
    45
    Re: ??s about moving sand filter
    You might want to read the section in Pool School about winterizing. I think there is some information there about disconnecting your pump and filter. If not, search out the manufacturer of your pool and see if there is info on their web site.
    24' Above Ground installed March, 2010
    22 Sand Filter With Zeolite
    1.5 HP Motor Pump
    Successfully using the BBB Method!
    pool-school
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I moved mine on a handtruck a few years ago. I disconnected the plumbing, drained the filter and moved it. I wouldn't tip it too far if you can avoid it.
