Thread: Bioguard Optimizer Plus
    jccams's Avatar
    Dexter, MI
    95
    We added this product to our pool this year after opening before I found this site. We had used it last year and it did give the water a "softer" feel. Is this product o.k. to use or will it cause other problems?
    24,000 gal vinyl Lazy L, 1 hp pump, DE Filter, Pentair 250K heater, Letro Legend pressure side pool sweep
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Bioguard Optimizer Plus
    perfectly OK...you now have borates in your water You may want to make sure it is at 50ppm to acheive the full benefit of borates...tftestkits.net sells borate test strips and the topic is covered in Pool School.
    jccams's Avatar
    Dexter, MI
    95
    Is there a cheaper product that will give the same benefits? I think I added 20#'s for about 50 bucks.
    Dec 2009
    Central Massachusetts
    2,690
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    yup...regular old Borax and muratic acid or you can use Boric Acid. I have ordered boric acid from the chemistrystore.com...with good results. www.poolcalculator can tell you how much product you will need.
