Thread: Order of gaskets on an above ground Skimmer
    Gilbertsville PA
    10
    The instruction I have with my skimmer would suggest that working from the inside:
    Front plate-Gasket-Liner-Metal wall-gasket.
    What I do not understand is why would you place a gasket between the Front plate and the Liner. There could not be a leak there since they are both on the liner side. Does this gasket seal where the screw go?
    It would make more sense to have the gasket between the liner and the metal wall.
    Is the theory that the gasket will press the liner evenly against the metal wall and since the liner is soft the liner will seal itself to the wall. I could use three gaskets but I would need to glue the 1 extra gasket to the metal wall since it will not be accessible once the liner is installed
    12 foot round above ground 48" deep. 1 HP paper filter.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Order of gaskets on an above ground Skimmer
    The instructions are right...there is always some moisture between the liner and the wall, but the liner will act as a seal for the wall/liner. The gasket is needed between the plate and the liner for the screws.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Just to chime in here. Each skimmer mfg may have a different gasket setup and procedure. Our Hayward widemouth has a single doublesided gasket connected at the inner edge so one side goes outside the wall between the skimmer and the other side DOES go between the liner and wall inside the pool. We also apply silicone sealer to the unit at installation. Follow the instructions with your skimmer since those gaskets are mfg to seal that particular molding on the unit.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Good point...bottom line, I would follow the instructions.
    Gilbertsville PA
    10
    Thank you all for your inputs.
