Thread: Do solar covers burn chlorine the same as open sunlight?
    Nov 2009
    Cleona, PA
    236
    That's about it. Will having my solar cover on while I'm at work keep the chlorine in? Or will it still burn off?
    This is the plain old bubble wrap like cover. I won't do those 'Solar cover in a pill'. Anything that says it puts a film on my water is not getting in my water.
    13,500 Wilkes Vinyl AG (15'x30' rectangular)
    Hayward Power-Flo LX SP1580, 1HP
    Hayward S-160T High Rate Sand Filter
    Toms River, NJ
    151
    Re: Do solar covers burn chlorine the same as open sunlight?
    The sunlight will still affect the chlorine in the pool. How much depends on your cover - what colour is it?
    Generally, the darker the cover the less chlorine is lost to sunlight, barring all other variables. The blue ones seem to be a good balance between letting the sun in to heat and block UV rays that destroy chlorine. If you have s clear one, then it may have little to no benefit in this regard.
    45,180 gallon 26' x 53' IG Vinyl, irregular shape. Hayward sand filter / pump. Polaris AutoClear SWG, supplemented with a Hayward Automatic Chlorinator (In-Line). Hayward 400K BTU heater. Paramount "turnover" system. Polaris 480 PRO cleaner.
    Nov 2009
    Cleona, PA
    236
    Well, if my FC holds overnight, I'll want it to start dropping tomorrow. (Means I'm done shocking!!! YEAY!)
    It's blue. We'll see. Best way to find out? Test!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    just don't use the solar cover until your done shocking...they do not like shock level FC
    22,553
    I have a clear cover and don't notice a difference in the amount of chlorine I use a day whether it's on or off. People with dark covers report a reduction in the FC loss when the cover's on, so you're right, you'll just have to check and see how your pool reacts to your cover.
