Thread: please help
    please help
    Fairly new to the pool scene.Just opened pool (inground 18x32) noticed pump was kicking off tripping breaker. Got a new 3/4 superflow pump. Pump will run for hrs, after I shut off pump very hot and has to cool down before timer kicks in, also notice my vacuume doesnt have the suction it used to have . Possible causes. please help LOL
    24' round 4ft deep above ground
    1.5hp proline pump
    Proline Cartridge Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: please help
    Sounds like the pump is too small. Or the filter is clogged. Or both.
    Re: please help
    original pump was 3/4 and supplier gave new hayward 3/4 pump superflow. how can i tell if I have a blockcage in any of my lines. the circulation in the pool is fine , just notice my vacuume manual doesnt have the suction it used to have and I notice my pump is quite hot but not tripping breaker. Only when i shut off it kicks on after 5 or 7 mins . I know the the pump has a thermal overload , and when pump is cool enough it comes back on. So therefore am thinking maybe a block somewere
    1.5hp proline pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: please help
    What is your pressure reading? Can you post the information on the plate, particularly the SF or Service Factor?
    Re: please help
    Not all 3/4 HP pumps are really the same HP as each other. Motor companies play this game where they label the same motor with different HP ratings for various marketing reasons. JohnT is asking about the SF, or service factor. The SFHP, which is SF * HP, is a better way to compare two motors.
