Thread: Getting ready to use Jack's Magic purple stuff
    Daytona Beach, FL 32117 USA
    35
    I want to try to avoid the ph up and down movement since I just spoke with the JM team. I want to use the Purple Stuff to control my scale problem. They indicated that I would have to keep my ph at 7.2 to clear up my problem and pretty much keep it there with maintenance doses to keep the scale away. I do not want to acid wash my tahoe blue Diamond Brite.
    I draned a foot of water from my pool on 5/22/10. My fill water has a ph of 7.2, ta 200, ch 180, and tds of 380. When I did my test on 5/23/10 my results were fc 2.5, ph 7.3 (added MA to try to bring ta down), ta 80, ch 260, and cya 40. Sunday and Monday I aerated the pool to get the ph up some and on. 5/24/10 my ph was 7.4 and my ta 80. Today I turned the jets down and my new test figures are fc 2, ph 7.5, ta 90, ch 270, and cya 40. My temp is 86 and I have a swg that is only on 35 % and runs only about 8.5 hrs. JM indicated I should only have to check my ph about every 3 days, but it seems like I need to do it everyday. Am I missing somehing as for as keeping my ph level? I live in FL so it gets hot and stays hot for a long time.
    12k Gal. Kidney IG pool (Built around 1964 screened enclosure?), Tahoe Blue Diamond Brite (Added 12/2007), 1 hp motor, Sta-Rite P2 pump, Hayward C900 paper cartridge filter, Resilience SWG PSC-3 SCC 25 Element, Dolphin Robatic Cleaner, Lamotte ColorQ Pro 11, Taylor K2006C, Lamotte Tracer PockeTester PH/TDS/SAL, purptiger
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Getting ready to use Jack's Magic purple stuff
    I respect Jack's as they make good products - but NO pool is identical and they simply can't say "ONLY every three days" because that's impossible to predict. They are just wrong on that, plain and simple.
    We advise folks to check PH daily anyway, until one "gets to know" their pool. If one's pool tells them "I need you to test my ph daily" then listen to it...LOL
    Even though the SWG is only at 35% its probably enough to cause the small drift. A TA at 60-70 may reduce it somewhat.
    35
    I can't seem to keep my ta in that range 60-70. When my ph goes ip the ta goes and seems to want to settle around 80 or 90.
    11,969
    Ok, it's probably your fill water that helps keep the TA in that range.
    Dec 2009
    Central Massachusetts
    2,690
    Just a note. I'm not sure how much the JM will stop or help scale. It is a sequesterant so it will bind some calcium, which is the main culprit for scale. The way to handle scale, really, is to watch the calcium level and not let it get too high. Second, watch the pH. higher pH will cause worse scale to occur if the calcium level is too high. The JM works well as a sequesterant for metals like iron and to some extent copper. But it's not really a magic (excuse the pun) bullet for scale.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
