Results 1 to 8 of 8
Thread: proper backwashing...
    Southern Maine
    4
    Hi People,
    Can someone fill me in on the "backwash" thing? How many minutes should I keep my filter on that setting a day if I am dealing with cleaning up a grubby and greenish pool? It's getting better with running the pump/filter and some chlorine, but my friend at work tells me I need to do the backwash thing a couple times a day for a couple minutes. I might need more specific directions! Also, does swimtrine really help as much as the pool store claims it does? It's awfully expensive...
    Thanks for the help! This is a great site that I have already learned a lot from since joining earlier in the week.
    Julia
    7,500 gallon above ground pool
    Hayward sand filter and Hayward pump
    Southern Maine
    Southern Maine
    4
    Re: proper backwashing...
    I am replying to my own post because I realized I left out important information that is supposed to go in my signature- I will figure out how to do that soon! Anyway, I live in Southern Maine, I have an above ground pool, a Hayward pump and filter. It's 1800 gallons. Sorry I am just learning the ropes! Julia
    Southern Maine
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Welcome to TFP!
    Swimtrine = pure liquid evil!
    It's copper based, so you don't want it in your pool. Plus it's freaking expensive (as you've already discovered)!!! How are you testing your water, pool store? We always recommend getting a good test kit and testing your own water. There is no pool problem that requires ridiculously expensive pool store chemicals to solve.
    If you post some current test results (FC, CC, pH, TA, CH, CYA), we will help you get it clear!
    Just saw you posted back...is 1800 gallons correct or should it be 18000?
    Jan 2009
    Cupertino, CA
    1,966
    Cleaning the filter happens when it needs it, rather than on a regular schedule. Any filter should have a pressure gauge, and if you have a sand or DE filter, you backwash when the pressure goes up maybe 8-10 psi over where you started when it was clean. If you have a cartridge filter, you don't backwash it, you open it up and clean off the cartridges by hand. Well, by hose.
    If you tell us exactly what kind of filter you have, we can be more specific.
    --paulr
    BBB "Intermediate Swimmer"
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    One word - chlorine. I've never heard of Swimtrine - I'm 100% positive you don't need it.
    Go to User Control Panel, then Profile, then Edit Signature.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP, Julia!!
    I'm gonna be moving to southern Me. before the new year and want to be on good terms with my new neighbors
    Paul and the others gave you the straight dope
    If you have any troubles next season, maybe I'll be able to hop on over and lend a hand in person
    Luv& Luk
    -Ted
    Apr 2009
    Burlington, ON, Canada
    344
    Swimtrine kinda rhymes with latrine, which is probably where it belongs.
    I've had very good success with what's recommended here - avoid the fancy named chemicals and get chlorine in there.
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    Southern Maine
    4
    Thanks Everyone!!!!
    Yes, the chlorine is helping a lot. We have moved to a light sage green. I guess the problem is also related to iron in our water. We actually have a water cooler installed in our house because our well has so much iron they don't recommend we drink much of it- especially the kids. This is fairly typical in our area of Maine. So, here are the levels we got at the pool store-
    Alkalinity- 40
    ph 7.6
    calcium 60
    iron 1.2
    chlorine 0
    I think that is it.
    Last time I thought I had 1800 gallons, but the pool people told me I have 7500. I'm a little embarassed, but I thought that was what I remembered...
    They recommended quite a large amount of chlorine as well as "staintrine" for the iron. They said we can use shock stuff in a couple days, but not until the iron level gets better or it will make the pool brown.
    The good news is that the water is pretty warm after all the hot days this week!
    I love this site- my son says it's my new facebook... I read all kinds of good stuff! julia
    Southern Maine
