Thread: Leader hose, weights, and flow indicator on a Polaris ATV?
    Are these needed? I got the 340 ATV for free with a broken belt and it just came with a regular hose, no leader, weights, or flow indicator. What's the difference between a leader hose and a normal hose section? My normal hose connects just fine to the cleaner. Can't I just count the wheel RPM and skip the flow indicator? Do you really need to weight the hose? My pool is about 15' x 28'. Thanks!
    15,000 gallon gunite pool, grey plaster with 8' raised spa
    Jandy PlusHP Pump 2 HP Dual Speed
    Sta-Rite 450 Sq. ft. Cartridge Filter
    Cleva-Chlor RP40HD
    Raypak 400k btu heater
    Jandy Aqualink RS-8 One Touch
    Savi Melody 12v LED lights
    22,553
    Re: Leader hose, weights, and flow indicator on a Polaris ATV?
    If it works fine without them then go for it. How long have you ran it in the pool?
    I havn't ran it yet. Just picked up new belts yesterday. I might try it out tonight if I get a chance.
    Cleva-Chlor RP40HD
