Thread: lattice removal from deck
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    I am getting ready to stain my deck using "One Time Wood" and currently have vinyl lattice air nailed around the base or skirting of the deck.
    Does anyone know a good way to remove said lattice without damaging it too badly so that it can be re-used?
    Why am I taking it off you ask?
    Because I don't want stained vs not stained lattice on the support posts. Don't think it would look very nice. I am trying to protect all of the exposed wood, not just the top surface.
    Any help or ideas would be appreciated.
    2005 Dimension One Venture model 370 gal. hot tub. We'll be using the TFP method to keep it clean and ready to use!
    TFP - The Finest Phorum on the Net!
    Pool-creetin's Avatar
    Mar 2010
    Michigan
    181
    Re: lattice removal from deck
    Getting behind there with a flat pry bar is the only way i can think of. Just be careful and not pry too much in one spot.
    26x16 rockwood keyhole vynil inground, waterway cartridge filter and swg, variable speed pentair pump, extra large skimmer with 2 main drains in deep end and 2 returns,Rheem raypack 206 natural gas heater, hayward tigershark qc robot. Being installed in late may early june. Woot!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    If you can see the nails, get a nail set and a hammer and drive them through and into the wood. Then reinstall the lattice by nailing in a different spot.
    No P in my ool's Avatar
    Jun 2007
    Logan IA
    219
    When you re-install it use screws. It will make it easier to remove next time.
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    Northeast Tennessee
    40
    I second the pry-bar method. That will be the best & it should come right off once you get the hang of it.
    AG, 27' round, 17,100 gallons, Sand filter, 3/4 hp pump
