Thread: Floating Pucks
    Ohio
    9
    Floating Pucks
    I'm using the BBB method for our pool. Should I also use the pucks in the floater.
    My pool:
    10,400 gallon AG, 1hp 2 speed pump, 21" sand filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    There is no need. The bleach takes care of the chlorination, and using the pucks will add CYA to your water.
    Houston, Texas, USA
    148
    Not to disagree with JohnT, but you do need some cya in the water if the pool is outdoors. You can use the pucks if you need to add some cya. Just don't let the cya get too high. Recommended range is 30-50 ppm.
    Poor Man's Pool
    Doughboy 18 ft round above ground
    7600 gal with center drain
    Pentair sand filter, 1 HP pump
    50 ppm borates
    "I know just enough to be dangerous"
    Pool Calc Ver 1.41 (Excel)
    You can use both bleach and the pucks to chlorinate your pool. Just don't pour bleach on or near a puck and you'll be fine. The big question is why do you want to? Not there aren't very good reasons for using pucks in a floater, just why do you think you need to?
    The thing we "preach" around here is understanding your pool and it's basic chemistry so you can make informed, un-biased decisions based upon your pool, not just what someone else (like a teenager in a pool store) tells you. Further more, to understand what you are putting in your pool as everything you had will have some other side effect or consequence. Get a test GOOD test kit if you have not done so.
    Dave
