Results 1 to 8 of 8
Thread: What size Autopilot
    donaldm823's Avatar
    Cape Coral, FL
    147
    What size Autopilot
    for Sean:
    I have a 30,000 gal concrete in ground pool and am considering installing one of the new Autopilot Digitals but am confused on what size. I have read that sometimes the size advertised is for a 24hr/day pump running. I only run my pump (single speed) 10hrs per day. So what size should I buy?
    Also, I have a 2hp single speed pump with 60ft3 DE filter and 2inch PVC runs to my pool approx 60 ft away. Based on my pump curves I think my pump flow is 120gpm to 140gpm. The Autopilot website says a max of 100gpm. What impact will occur if I install the Autopilot anyway with the SWG loop that is sold with the digital? I do not have enough room to install another bypass loop
    Don SW Florida
    10,000 gal in ground concrete pool
    Pentair Cartridge filter, Pentair SWG, Pentair Intelliflow VS pump (11018)
    FAFCO solar panels w/Pentair SolarTouch controller
    using BBB for pool chemistry/Lamotte ColorQ tester for daily testing
    Ft Lauderdale, Florida
    1,455
    Re: What size Autopilot
    Quote Originally Posted by donaldm823
    for Sean:
    My recommendation is to always get the largest cell you can afford. You will get more chlorine production and longer cell warranty. That would mean the SC-60 cell.
    The excess flow will reduce efficiency somewhat. So going with the larger cell will help offset that. You'll be good with the Digital with the SC-60 cell.
    Thanks for selecting Pool Pilot.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    DaveNJ's Avatar
    Toms River, NJ
    520
    There shouldn't be a problem. I have 2.5"piping. If you go to the "Stickies at the top of the page then "Hydraulics 101" you will see that 2" pipe won't flow 120-140gpm. Very good write up by mas985.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    I would go with the SC-60, but I am sure the SC-48 would be fine. The SC-60 will last longer and so be less expensive in the long run.
    Jul 2007
    Brisbane, Australia
    874
    You need something which makes around 50 grams of chlorine per hour for that pool size and running time.
    From experience this can be rather complicated.
    The size of the unit depends on the amount of water, the temp. of the water and
    how much UV you get from the sun.
    In the northern climates the sun angle is lower so the UV is less, also the water temp
    is usually lower so there is less chlorine consumption.
    The output of the unit can be controlled by the pump run time and the settings on the
    unit. You can always turn down a larger unit but you cannot turn up a too small unit.
    With ever increasing electricity rates one would want to run the pump as little as possible.
    This dictates getting as big a SWG unit as you can afford. The larger units will cost more initially,
    but with the reduced pump run time to generate enough chlorine they will easily pay for
    themselves in savings on your electric bill.
    As you can see the largest unit you can get will be the lowest cost to run.
    In AZ where I live the largest unit will just barely make enough chlorine on a 110 deg. day.
    The rest of the year it will make too much and the pump run time will have to be reduced
    or the unit output turned down.
    Cliff s
    cliff_s is right, you better off with oversized machine than undersized!
    In regards to how big machine do you need, you first need to answer " what is your chlorine demand".
    If you do not know, than take recommended average machine and go next size up.
    example:
    25 gram chlorinator will do:
    3000 gallon heated commercial spa OR
    30000 gallon private fiberglass pool
    It's all about chlorine demand not the volume of the water...
    donaldm823's Avatar
    Cape Coral, FL
    147
    Using SC-60 size Autopilot
    Quote Originally Posted by cliff_s
    Cliff s
    Just to close the loop. I installed an Autopilot Digital with the SC-60 cell in mid-August. I live in the Philadelphia area and my back yard faces south so the pool gets full sun during the day.
    In August and early SEP (still 85F-90F days), I was running the cell at 40%, Power 2 (mid power) to maintain 2-3ppm chlorine with CYA only at 30ppm (I elected not raise the CYA to 60ppm per SWG recommendations based on it being near the end of the season). The SC-60 managed well to keep my chlorine level with the 2hp pump running 10hr/day even with CYA at 30ppm vice 60ppm. Near the end of the season (late Sep), I was running the SWG at 40% power 1 (lowest power setting). Please note I have a heater and a solar pool cover, so the pool temps were kept in the 80-85F range.
    From all appearances, the SC-60 although bigger than needed, is producing the chlorine amount as advertised and all of the recomendations to buy the next largest cell size for your pool is right on the money. I bought the SC-60 for my 30K gal pool based on my running the pump only 10hr/day. BAsed on my experiences-it looks like 40-50% setting will be the norm, but I will have to raise CYA to manage the direct sun in the Jun-Jul time period. I also found that I needed to use at least a 30% setting on the SWG (with 10hr/day pump run) or my CC would rise during the day-but still it never got higher than 0.2ppm.
    Don SW Florida
