Thread: More POP needed or doing something wrong?
    Jul 2008
    Bucyrus, Ohio
    108
    Got filter hooked up middle of last week, water was soo green cause it remained uncovered all winter(leak in liner). Filled with water and turned on filter and pump all working great. Had NOTHING in the way of chemicals left in pool of course since it didnt get covered. I have put in 2lbs of Stabilizer, and 16 gallons of bleach, we are still very milky not green but just cant get it to clear. When I vacuum I can only go abit before it sends the pressure thru the ceiilng. I backwash and move on. Should I just put the hose in the pool keep filling and vaccum to waste? Is there something I am missing?? I brush the pool each time I go out, stir up alittle bit but nothing much. I think I am really really lose here.
    Overwhelmed
    Pool size: 15' X 48" AG vinyl liner, 5300 gallons, Hayward S166T filter and 1hp pump
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: More POP needed or doing something wrong?
    Please post a full set of numbers:
    FC
    CC
    pH
    CYA
    CH
    TA
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Jul 2008
    Bucyrus, Ohio
    108
    Quote Originally Posted by svenpup
    FC
    CC
    pH
    CYA
    CH
    TA
    FC 25
    CC 2
    PH 7.8
    CYA 0(adding 2bls via sock method)
    CH ?
    TA ?
    Overwhelmed
    Jan 2009
    Cupertino, CA
    1,966
    Vaccuum to waste sounds like it would help, as its clogging the filter so fast. Once the stabilizer is in there, that will help, as you've probably been losing significant FC to sunlight.
    --paulr
    BBB "Intermediate Swimmer"
    Jul 2008
    Bucyrus, Ohio
    108
    Just check my FC and its at 32 and my CC was .5...hopefully I am heading in the right direction. I am still sweeping and vacuuming every hour or so. Do I keep the FC high? and if so for how long?
    Overwhelmed
    22,544
    Keep it high till you have .5 CC or less and an overnight chlorine loss of 1 or less. You'll need to do an overnight chlorine loss test with a FAS-DPD kit to tell when you're done shocking.
