Thread: Trichlor Paperweights
    So before I found this site I bought a HUGE bucket of the trichlor pucks...
    My pool looks good - CYA is 60
    I want to use the BBB method...but I have $80 worth of trichlor sitting in my garage....
    Can I use them at all, and stay trouble free? Or am I stuck with a really expensive bucket?
    16K Gal in-ground Vinyl, Sand Dollar sand filter, Haywood pump
    Mar 2010
    Spring, TX
    1,082
    Re: Trichlor Paperweights
    I assume you do not have a SWG. If you are going to be using the BBB method and with your CYA that high, they can be used but I would only use them if you are going to be gone on vacation for an extended period of time. I think if you ever get algae on your pool surface, you can use them on those. Otherwise you can try to take them back if possible or sell them on craigslist or something.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Jan 2009
    Cupertino, CA
    1,966
    I have my lifetime supply of pucks out in the shed too. Expanding on what mynewpool said...
    - they are ideal for vacations
    - if you keep the bucket sealed up they should last for years
    - if your CYA drops a bit over the winter, you can switch to pucks for a while in the spring to boost it back up (although if it drops to zero, you might be better off just buying some straight CYA)
    --paulr
    BBB "Intermediate Swimmer"
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    I have a 2 year old bucket that I keep for vacations, that is all I use it for now.
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
