Results 1 to 8 of 8
Thread: Is My pressure to high?
    I have a Hayward S180t sand filter and I just replaced my faulty pressure gauge yesterday. The pressure is now at 20, but the manual says bar is 3.45. I backwashed the filter for about 10 minutes, but pressure remained the same. Am I ok, or is there something else I need to do?
    Thanks!
    24' Round 14K Gallons
    Hayward S180t Sand Filter
    1hp Hayward Powerflo Matrix Pump
    Aquabot Pool Rover Jr.
    22,550
    Re: Is My pressure to high?
    20 PSIG could be prefectly normal for your system. What size eyeball do you have? I have a 1" eyeball and my pressure runs 11 PSIG clean my Sis has a ½" eyeball and hers runs 18 PSIG clean. It all depends on the makeup of the system.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Mar 2009
    Huntsville, AL
    156
    Don't know if it helps, but 3.45 bar is approximately 50 psi.
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    maybe 3.5 bar is the max pressure for which the filter is rated?
    Stupid question....Eyeball is what?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    The eyball is the last little adjustable part on your return jet inside the pool that allows you to direct the water flow. They are referring to the hole size in the "eyeball".
    22,550
    Not stupid. It's the part in the pool on the return that the water comes through. Most of them you can swivel around, like an eyeball, hense the name!
    AH! Learn something new every day! I will check it when I get home. Again, I really appreciate all the help I'm finding here.
