High Chlorine Loss but no CC
Mar 19, 2010
24
It possible to be losing FC to organics even if testing is showing less than .5 CC. My CYA is 50-60 But I seem to be losing a lot of FC. I added bleach to get it up to 7, yesterday just before sundown. (although I didn't do a drop test to confirm after adding the bleach. I do know it jumped up to 5+ afterwards based on the basic test)
Today at 5:30 pm it was down to 3.5 Does that sound reasonable due to sun alone? Should I be doing an overnight FC loss test even if I don't have an issue with CC?
Thanks!
Yes, you can have algae or other organics and not have any CC.
With CYA around 50 I would expect you to lose around half of your starting FC level over the course of a sunny day. That fits what you described very well.
So chlorine loss to sun is typically a percentage rather than an absolute number? If i bump my starting FC up to 8 or 9 I should still expect to lose half that? I was under the impression 2-3 ppm was more the norm....learning new stuff everyday on here.
On a related note, what's the best way to keep the FC where it needs to be if you're away from the pool for a few days? I was using the pucks in a floater before swithcing to BBB so it wasn't an issue.
