Thread: 5/8 inch drill bit for blue-white flowmeter
    Apr 2010
    Escondido, CA
    14
    Largest "regular" drill bit I have is half inch and that's the largest one at HD. What did you use to drill the 5/8 inch hole the flowmeter requires?
    30k IG pebble pool + spa, Hybrid X2 pump, Sta-rite S8D110 53sf DE filter, TF100 test kit, SGS Breeze 760 SWG
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: 5/8 inch drill bit for blue-white flowmeter
    A spade bit should work. They are readily available up to 1.5" or so.
    22,553
    Hole saw. Harbor Freight has a set for $2.99.
    Apr 2010
    Escondido, CA
    14
    Harbor Freight doesn't have a set that goes down as small as 5/8.
    22,553
    I have two sets of them that go down to 1/2". Maybe every store doesn't stock them.
