Results 1 to 14 of 14
Thread: Green algae in 24' intex
    May 2008
    gulf coast of Texas
    166
    Here are my current numbers:
    FC 1.5
    CC .5
    pH 7.5
    TA 160
    CH 440
    CYA 20
    I know I need to lower my TA, CH and up my CYA. CYA is coming up slowly as the number was lower a few days ago. I'll post a pic of my pool water in a bit. I bought 19 (96oz) bottles of bleach. Think that will be enough, or do I need to buy more on hand? Also bought another bag of DE as I'm nearly out of my other one from bumping and dumping. So I haven't had to fight algae before. When is the best time to start this? Morning? I know it says to run the pump/filter 24/7...but do I have to wake up at night to go out there and bump it??? I really don't want to do that as we live out in the country and the pool is away from the house...afraid of snakes or whatnot that roams out here. LOL
    Julie
    Atlantic Pool Products "Prestige" metal wall pool 18' x 48" round
    vinyl liner
    Hayward Power Flo pump
    Hayward Perflex DE Filter Model EC50AC
    Re: Green algae in 24' intex
    Start by reading How To Shock Your Pool in Pool School. That should answer some of your questions.
    The fastest way to deal with algae is to do it intensively all at once, checking and adding chlorine every hour, but you can work at it more slowly if you want/need to.
    Shocking in the evening is slightly more efficient, since you lose less chlorine to sunlight, but shocking during the day works just as well at killing algae. If day time is good for you, then do it in the daytime. If the filter pressure is going up rapidly and you can't be around to deal with the filter you can turn the pump off till you get back. Just be sure to run the pump for at least an hour after the final chemical addition and don't leave it any longer than you have to.
    May 2008
    gulf coast of Texas
    166
    Thanks Jason!
    Julie
    vinyl liner
    May 2008
    gulf coast of Texas
    166
    Okay, new numbers...just did the drop test
    Last night 10pm:
    FC 30
    CC 0
    This morning 7am:
    FC 21
    CC .5
    Water looks 90% BETTER!! I can see the bottom! There is a patch of algae on the other side of the pool and the problem is..I can't get to it. Can't get in the pool cause I just got an ankle tattoo last weekend and theres no deck so I can stand higher to brush it. I'm short 5'1". Will have to get DH in the pool as the kids will swim and play if I put them in to do it. LOL
    Julie
    vinyl liner
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    keep on a shocking, and maybe find a step ladder to brush that algae
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    May 2008
    gulf coast of Texas
    166
    There is a LOT of **** on the bottom of the pool. I guess its dead algae? Its all brown, but fluffy...like dirt...but not dirt. does that make sense? LOL I have started to vacuum it up...but getting up on the ladder...vacuuming...then getting down to bump the filter...and so on..its really tiring. And it fills up with the **** quickly...so I'm having to drain the used DE and **** out and putting in new DE. Is there an easier way to do this? Can I vacuum to waste? But the thing is...when I open the drain..it makes a HUGE wet mess on the ground. Do they make a hose I can attach and run out to the pasture for the dirty water and gunk? I don't mind vacuuming to waste..but I need to figure how to get it to drain out away from the pool because its becoming a slosh pit there now.
    Can you even vacuum to waste with a DE filter?? I never thought about it. I have the Hayward EC50 DE filter.
    Julie
    vinyl liner
    22,551
    Yes!
    They do make a hose that attaches to the discharge of the multiport to route the water to whever you want it. It's a flat hose and you just clamp it on and roll it out where you want to. With the proper fittings you can connect them together.
    It all depends on your multiport valve. Most of them have a "waste" setting but some do not. You'll just have to look and see.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    May 2008
    gulf coast of Texas
    166
    Okay..I don't have a mulitport valve on the drain. It just came with a cap that screws on. The only multiport valve it has the at the top were the return hose is attached. I look in the handbook and it shows that a multiport valve(or ball type drain valve as it lists in the book) is optional. Where can I buy one of these at? And do I need to measure the opening or something to get the right size? And the hose? Can I get these at the local pool store or where would I get them?
    Julie
    vinyl liner
    22,551
    The multiport valve is the one that has the "waste" setting on it if it exists. Take a pic of it and post it if you can.
    May 2008
    gulf coast of Texas
    166
    There is a ball valve on it, but I don't think I have a multiport valve on it. Will go out and get a pic.
    Julie
    vinyl liner
    May 2008
    gulf coast of Texas
    166
    here are the pics
    Julie
    vinyl liner
    22,551
    Your right, you don't have a multiport. You can buy an adaptor that will screw into the place that the drain plug is in now and the hose will slip onto it.
    May 2008
    gulf coast of Texas
    166
    So anyone know where I can buy another valve and that hose at? Like, do I find it at a Lowes or Home Depot?
    Julie
    vinyl liner
    22,551
    Yes, either of those will have the hose and the adaptor. They have blue hose in rolls so you can buy as much as you need. That looks like an 1½" plug but your best bet is to take it with you to whever you get the adaptor at.
