Results 1 to 7 of 7
Thread: How much evaporation is normal?
    Nov 2009
    Katy, TX
    94
    Hello again...I am in the Houston area, where the summers don't wait for the June date. I have noticed an increase in salt ppm's and started to monitor the water level. 10 days ago, we had a good rain shower that filled the pool to the rim...today, (10 days later) i see a gap of about 1 inch. Is this reasonable evaporation or should I go to phase II (bucket test)?
    your comments are much appreciated !
    Inground with 7x7 spa (spillover)
    20k gal plaster (sunstone)
    pentair 3/4 hp (filter), 1 hp (spa), 1/2 hp (features)
    cartridge filter
    SWCG IC-40
    Polaris Platinum (with booster)
    22,543
    Re: How much evaporation is normal?
    I'd say 1" in ten days is not only good but almost exceptional. We can lose ¼" per day around here easily.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Nov 2009
    Katy, TX
    94
    Woao..Thanks, I guess I can put my worries aside for now....Thanks for the reply..
    cartridge filter
    SWCG IC-40
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    A bucket test is cheap... peace of mind is priceless.
    Mar 2010
    Spring, TX
    1,082
    I am in Spring, TX and I noticed a lot of water missing due to evaporation. I did the bucket test and it showed nothing overnight. It makes me feel better as I have a Koi pond that is totally shaded and it is losing water at a slower rate, but is losing water.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Mar 2007
    San Rafael, CA USA
    12,082
    The bucket test for evaporation is something you should check over a 24 hour period on a typical day with sun (if that's normal). The evaporation rate can vary somewhat from day to night so you really need a 24-hour period for a reasonable test. This isn't like the chlorine demand test where you don't want sunlight to interfere.
    Nov 2009
    Katy, TX
    94
    ok..thks for all your replies..I guess the test won't hurt...adding to the learning experience...
    srg
    cartridge filter
    SWCG IC-40
