Opened yesterday morning but I couldn't run the pump as the water was still below the return.
I had these numbers-
FC WAS 15 yesterday, but now 13.5
CC - 0
TA 70
Borates 40 -45
Salt 2900
PH 7.45
CYA 30-35
CH 70-80
Now they're slightly different as I added salt and other stuff to adjust numbers. Today the FC was still 13.5
I've added salt, borax, CYA, MA.
The swg seems to be off now, although it was "ON" yesterday upon startup until the orp reading showed it was past the setpoint. I'm hoping it won't turn on for a while until the FC goes down to at least 6 or so.
CYA at 40 or less has shown to work on my pool. TA about 70 has also shown to work. The PH is always spot on (7.5) with the acid feed tank/system controlling it.
It's pretty impossible for my FC to hang around 2 or 3. What suggested FC level can I have with these numbers? Would 6 be too high? I doubt I can get lower than that with this system functioning properly. The pool is small and the 48 Cell is probably too large for the 7600 gallons in my pool.
My pump runs 24/7 on low speed.
I can't believe the water was clear with about 5 leaves in there when I took the cover off yesterday. Wow! BBB!!!!
Thanks for reading.
CC - 0
TA 70
Borates 40 -45
Salt 2900
PH 7.45
CYA 30-35
CH 70-80
Thanks for reading.
