Results 1 to 7 of 7
Thread: How much chlorine/bleach- too much produces false readings?
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    I've only had my pool open 10 days; I added 182 oz of bleach over 4 days; and added 4 lbs of CYA over two days.
    As I mentioned in a previous post- my FC (through OTO testing)- indicated 2 ppm 24 hours after my last addition of any chemical.
    I added 71 oz of bleach as indicated on the pool calculator to bring FC to 4 PPM.
    24 hours later- it hardly looks like there is any chlorine in my readings.
    I've read on the internet that too much chlorine can actually throw readings off to indicate little or no chlorine in pool
    Having added 250 oz of bleach in ten days- surely this is the case right?
    How much chlorine or bleach do you add daily or weekly under "regular" conditions when you get going?
    Intex 22' x 52" - Intex Krystal Clear Sand Filter Pump - flow rate: 2,150 gal per hour
    TFTest Kits TF-100
    Waiting to stop relocating until I build my dream pool!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: How much chlorine/bleach- too much produces false readings?
    You would normally expect to add enough for 2-3ppm per day, but this is a generalization. For your pool, that would be 71 to 106oz per day. Most likely you need more chlorine.
    Very high chlorine levels ( above 10ppm ) will skew a PH reading to the high side . With the proper test kit you can measure chlorine to 50ppm or more. Your chemistry is only as acurate as your testing. What test kit do you use?
    Chlorine will be consumed by several sources, sunlight splash out etc. If you can , test your CYA ( stabalizer ) level , provided it has been at least a week since adding it. Your chlorine consumption sounds fairly normal so far.
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    That range of bleach per day throughout the season? Wow- I didn't realize that. My CYA is about 40
    TFTest Kits TF-100
    22,537
    If you're using the OTO chlorine test, it doesn't wash out. You may not know how much chlorine you have in there but if there is any it'll change color. The DPD test will wash out above a certain FC level.
    250oz of bleach is almost nothing for a 27' pool over ten days. I use more than that a week in a perfectly balanced pool. Our pool averages 48 oz of bleach per day with a CYA level of 50ppm.
    Mar 2007
    San Rafael, CA USA
    12,082
    48 ounces of 6% bleach in 14,660 gallons (24' round x 54") is around 1.6 ppm FC per day which isn't bad, especially for 50 ppm CYA.
    Jan 2009
    Cupertino, CA
    1,966
    Quote Originally Posted by cfclay
    That can happen with the DPD chlorine test (add drops to the sample to turn it shades of pink, and compare to a color block). The other chlorine tests (OTO and FAS-DPD) don't have that problem.
    --paulr
    BBB "Intermediate Swimmer"
