Results 1 to 17 of 17
Thread: Fat Goose egg on Chlorine
    May 2009
    Topeka, KS
    81
    I just had my water tested. They suggested to shock the pool. Since I beat around the bush on the BBB method. Can't I just put more bleach in, instead of buying shock?? My pool is 18x36 with a deep end. To open over three days I put 6 gallons of bleach in it. Yesterday I didn't do much other than run the pump. The water is teal, and cloudy after 1' deep. Thanks for all you help. Jason.
    18x36 Buster Crab in ground, 3' shallow 8' deep, Hayward super pump, 300lb sand filter.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Fat Goose egg on Chlorine
    Sure you can use bleach. Check out Shocking Your Pool
    You'll probably need bleach additions several times a day, based on test results, until the pool starts to clear.
    Posting those numbers would help us determine what action may be needed.
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    May 2009
    Topeka, KS
    81
    18x36 inground with a deep end. (Buster Crabbe)
    CYA 50
    TOTAL CHL .3
    FREE CHL 0
    PH 8.8
    ADJ TOT ALK 290
    TOT HARDNESS 83
    Thanks if you guys can help me out!!! Jason.
    Start by lowering your PH to 7.0. You should do this in a couple of partial steps so you don't overshoot and get the PH too low. Your TA is rather high, so you will need to keep an eye on the PH and lower it back down to 7.2 every time it gets to 7.8.
    Once the PH is under control, add some bleach to bring the FC level up to about 20.
    Your CYA and hardness are good.
    May 2009
    Topeka, KS
    81
    You think 2 quarts of Muriatic Acid to start?
    Mar 2010
    Spring, TX
    1,082
    2 quarts is going to be 64 ounces and that will lower approx .96 on the pH (based off of the pool calculator at http://thepoolcalculator.com/ ), so down to around 7.9 or so. If your pH level is that high you will defintely not overshoot. So I would get a gallon of acid and add half of it and that would be the 2 quarts. Then get the water tested if possible about an hr after that. Then depending on what your result is then you will more than likely have to add more acid. So I would maybe go ahead and get 2 gallons as I am sure you will need more and this will cause less trips to the store. My pool store sells it in 4 gallon box for around 20.00, which is a little less than 4 at home depot or lowes.
    How did you get your test results? I assume at your local pool store?
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    May 2009
    Topeka, KS
    81
    Yes at a local pool store that I actually trust...
    I grabbed a gallon of acid, so I should get that down tonight or by the morning? Should I go ahead and get it tested in the morning again?
    Also should I totally hold off on adding chlorine until I have the Ph down? I will need to be told by someone not to shock it tonight... LOL
    Sorry this is the 3rd time opening the pool.
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by cortlinsdaddy
    I can not answer about the chlorine, but from reading here I would say go ahead and add some chlorine, but with your pH level so high the chlorine may be ineffective. If the pH level is around 8.8 or so the gallon of acid will drop it 1.9 or around there and put you below 7. So I would do half and then get it tested again as soon as you can and then you can go from there.
    May 2009
    Topeka, KS
    81
    Thanks man I'll do 1/2 and see if I can get it tested before I jump the gun on anything. I really appriciate all the knowledge on this site!
    Butterfly's Avatar
    South Carolina
    10,045
    As mynewpool mentioned, some is fine. Stay under 10 FC.
    Do not shock until you have your pH around 7. See Jason's comment:
    Once the PH is under control, add some bleach to bring the FC level up to about20.
    Do you have a test kit? If not, you need one! Please read pool-school/pool_test_kit_comparison
    You're done SLAMing when:
    May 2009
    Topeka, KS
    81
    Okay:
    CYA 100
    TOTAL CHL 10
    FREE CHL 10
    PH >8.8
    ADJ TOT ALK 180
    TOT HARDNESS 79
    I can see the shallow end of the pool now. Still cloudy but in the 4 hours since I seen it, it's much much better. Over the lunch hour I ran the pump on waste to clean out the filter. I did end up putting a gallon of Mur. acid on the other day, and put maybe a quart in this morning.
    These number look okay?
    On the 24th your CYA level was listed as 50, now it is listed as 100. If those numbers are correct there is one problem, and if they are wrong there is a different problem.
    Your PH as been listed as 8.8 each time, which is way way way too high. You need to keep PH between 7.2 and 7.8. However, most PH tests won't measure as high as 8.8, so I am not sure where you are getting that number. I would have expected a gallon of muriatic acid to have lowered the PH enough that it would no longer be 8.8. If FC is actually above 20 the PH test results could well be wildly off and should be ignored.
    I am also concerned that your FC and TC levels might be well above 10. One of the common FC/TC tests won't measure FC/TC levels above 10, so that could be a testing problem.
    Nothing makes a larger difference than having reliable test results. What you need to do next depends a great deal on how reliable these results are. It seems likely that they are wrong, but it is possible for them to be correct. Could you tell us more about how you are testing?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    pool store tests...
    May 2009
    Topeka, KS
    81
    I have been taking my samples into a pool store that I do trust. (why I have no idea) When I take my sample I hold the bottle upside down and flip it over elbow deep in the deep end, So I'm not just taking the water off the top.
    After I vacuumed the pool floor, my wife dumped in a box of borax and a thing of baking soda. I thought that she should wait until I got the water tested. But what is done is done. I have put in a gallon of acid, and did buy another gallon today. I'm wondering if their tester does not go above 8.8 and mine is much higher than 8.8.
    I do have a cheapo tester, and plan to buy the one that is recommended on this site.
    Thoughts? Dump in another 1/2 gallon of muriatic acid in and retest? Possibly go to (eeekkk) another store to test? I promise I will buy the good home test kit!
    Oct 2009
    3,899
    What kind of kit do you have? The pH tests are all based on the same indicator dye, so what you have should work for getting pH at least in range.
    I think you should: test with your whatever kit you have (probably goes to 8 or maybe 8.2), and add enough acid to get to 7.4 assuming that your result actually is whatever the highest possible reading is. So, even if you think your pH is 8.8, add enough to get from 8 to 7.4. Then, wait a half hour or so for it to circulate and retest. Repeat as many times as necessary.
    May 2009
    Topeka, KS
    81
    Well my pool is very very clear now! I appriciate all the help, with my start up.
