Results 1 to 8 of 8
Thread: My filters pressue gauge is stuck-what to do?
    I have a Hayward S180t sand filter, and we noticed yesdterday that the pressue guage is locked on and doesnt move. Whats the best way to replace this?
    Thanks!
    24' Round 14K Gallons
    Hayward S180t Sand Filter
    1hp Hayward Powerflo Matrix Pump
    Aquabot Pool Rover Jr.
    22,537
    Re: My filters pressue gauge is stuck-what to do?
    It should be a back connection ¼" NPT. Just unscrew it and screw the new one in it's place. You can get them at either the pool store or your local big box store (Lowes, etc.) will have them. Just match the range you have now and be sure to use sealant (t-tape or paste) on the threads.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Ok..stupid question....I'm new to this
    If I remove the pressue gauge from the filter, water will start coming out, which I assume is a bad thing. Do I need to turn the handle up top to a certain setting?
    Mar 2010
    Spring, TX
    1,082
    I would say just turn the pump off.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    22,537
    Turn the pump off and close the skimmer and return valves. Just like when you clean the pump strainer basket. There will be some water come out but it won't be much.
    Valves....Hmm...I guess next year I need to add some turnoff valves to my setup as everything is pretty much directly connected.
    On the plus side, I have the new valve.
    22,537
    If your multiport has a closed position, turn it to there and that should help.
    Cool. Mine has that so I will do that. Thanks for all the help!
