Results 1 to 7 of 7
Thread: GVA-24 solar diverter
    I have a GoldLine Controls GVA-24 and the diverter will only automatically turn to the POOL position, meaning when the roof is hot enough it will not turn to the SOLAR position?
    This was working last weekend, and since a couple of days ago it has just stopped...
    I have checked all the Sensors and everything is fine, any guesses on what the issue could be other than a defective diverter?
    John
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: GVA-24 solar diverter
    Try manually switch the actuator back and forth (silver toggle on bottom of actuator) to see if the actuator is working. You can also turn solar on manually via the controller to see if that part is working as well. If both the actuator and the controller are working, it could be the temperature sensor near the panels which is not working.
    What controller do you have?
    Mark
    The controller is a Aqua Solar AQ-SOL-LV
    When I switch the controller to the "solar test" position the actuator does not turn to the Solar position, if I manually turn it to the Solar Position and set the controller to OFF the actuator turns to the off position. It's almost as thought the actuator can not turn the opposite way?
    I have checked the temperature sensors and they are both working correctly.
    John
    You should try what mas985 suggested, see if the valve turns when you use the switch that is directly on the valve actuator, not the one on the solar controller. That will tell you if the problem is with the actuator or the controller/wiring.
    I will try that when I go home, I just don't recall seeing that switch...
    I'll keep you informed...
    John
    mas985's Avatar
    Pleasanton, CA
    11,737
    The switch is on the bottom of the actuator, closest to the valve. It is hard to see but feel underneath and you will find it.
    Mark
    You guys are good!
    I must have fat fingered that switch It's been so long I forgot all about it.
    Thanks again!
    John
