Results 1 to 7 of 7
Thread: Possible to make a 27' Round pool into a 24'?
    Have an opportunity to get a 2 year old 27' foot setup (complete with extras) - it does need a new liner though.
    Anyway I am 99.99% sure we can do a 24' round w/o trouble and still have enough deck exiting the house to actual exit out on. The 27' becomes iffy. I think it is still doable but I cannot be sure.
    If I knew for sure I could take this 27 and make it a 24 I would probably do the deal.
    I saw 1 thread here where someone had asked about doing this with a Doughboy and there was no real concensus either .. just a maybe.
    After some research the pool appears to be made by Lomart. The pool is this one here http://www.intheswim.com/Backyard-and-H ... und-Pools/
    TIA for advice you guys/gals care to share.
    Greg
    27' x 52" Round Lomart Sandstone AGP
    ~ 18,000 Gallons
    Hayward S244T Sand Filter 300lb
    Hayward 1HP Matrix 2 Speed pump
    2" Plumbing - 50 Foot run buried 18" Deep - Widemouth skimmer and 1 return with eyeball
    Compupool CPSC24
    Exton, PA
    249
    Re: Possible to make a 27' Round pool into a 24'?
    Here's what I can tell you. I had a 54" round kitchen table with tile insert. I removed the tile and wanted to use the outside oak ring for a 50" or 52" poker table. I was really after the base, but thought that the oak ring would make a nice touch.
    Well, there's no way to reduce a 54" circle to a 50" or 52". I'm sure someone can chime in with the technical rasones why that is. But but once you cut the circle, the circumfrance is lost. Do a Google on circles and you can get the explanation there as well.
    Now, what does that mean for a pool? I have no idea, except your are still talking a circle and my guess is that the peices are curved to make a 27' circle and not a 24'.
    18' AG pool, 7,646 gallons, Sun from 11:30AM-2PM.
    Pentair Dynamo 1hp pump, Intermatic Timer (6/17)
    Pentair Sand dollar filter - 100lbs, 35gpm
    Pentair Lil' Shark cleaner, TF-100 Kit
    Raypak 206A 200K, BTU gas (6/17)
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    You will not be able to change the radius evenly all the way around from the center of the new "circle". I work in autocad------trust me.
    Exaggerate the problem by trying to imagine reducing a 1,000 ft circle to a 100 ft. circle and you'll see the problem
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Call the manufacturer!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Check and see if the yard is large enough by making a 29' circle with flour in the area where you would want to put it. Making the circle a couple of feet bigger gives some room for error.
    Love TFP? Become a
    TFP Supporter!
    Tim23's Avatar
    Feb 2010
    Livingston, Louisiana
    61
    Theoretically you could shorten the wall portion of a 27' pool to the diameter 24' by cutting off some length of the wall itself. I would NEVER attempt such a thing due to possibly loosing strength. But the lower and upper rails would be at the wrong angle for a 24' pool. They are bent to fit the diameter of the pool itself. Now if you could just invent an adjustable AGB, that would be trick!! Just my 2 cents
    Tim
    Delair 27', 52" round AGP. 19,300gal
    Waterway 22"/1.5hp pump, 2 speed/sand filter, BBB
    My BBB motto.."LESS IS MORE WITHOUT ALL THE CHORES, SO FOLLOW TFP AND IN THE END, THE POOL OWNER SCORES"!
    You'd need 24' pool tracks, even then, you might end up with the first and last upright really unequally spaced compared to the rest of them.
