Results 1 to 16 of 16
Thread: Harsh water
    Apr 2010
    Buckeye, AZ 85326
    619
    Harsh water
    We had our first pool party Saturday. The pool was a big hit thanks in part to this forum. I did hear mention of dry itchy skin after swimming. It was windy which probably didnt help. All of my test numbers were on the money the day of the party. Is there anything I can add to the water to make it more swimmer friendly?
    Thanks
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    May 2009
    West Tennessee
    33
    Re: Harsh water
    If your water is properly balanced there shouldn't be any dry itchy skin. If you haven't already added borates you can try that. To me it makes the water feel better... softer. Also adding salt may help a little.
    29,000 Gal. 18' X36' Vinyl - IG- Hayward 1HP Superpump with Haywrd 250# Sand Filter- Circu-Pool RJ 45 SWG - GO VOLS!
    Feb 2008
    Denton, TX
    5,061
    Re: Harsh water
    What were your test numbers on the day of the party? Normally, properly balanced water causes no untoward effects to skin. You could have developed some CC due to the number of swimmers in the pool during the party as is common. This may also be sun related.
    I usually run a little higher than required FC during the course of a party. My target, based on my CYA level, is 6 ppm. I'll bump it to 7.5 for a party with lots of swimmers. It keeps my CC down that way.
    22,551
    Re: Harsh water
    I'd like to see what he numbers were. I guess I'm spoiled but I really like knowing the numbers.
    Back to the question at hand. If it was pretty windy and hot that tends to dry the skin out fast and cause itchyness. Also, as mentioned, adding about 2,000ppm salt helps the water feel soft and actually feels better to the eyes.
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Not the water perhaps?
    Hello~
    Glad you had a successful party~
    It is very possible that the alleged dry itchy skin had nothing at all to do with your pool water. Was your own skin dry and itchy?
    Some people have dry skin. I have dry skin, now that I'm older. I've never been to Arizona, but don't folks like it there because it is not humid and jungle-like? Seems to me that some people will suffer from dry skin in Arizona.
    Also some people are a little neurotic and just knowing they were in a pool that has--OMG--chlorine in it is enough to start them scratching.
    The above posters' water-enhancement ideas will be something you might appreciate doing for yourself, and the next time around, you might mention to your friends that you have added some special products to your water just for them!
    Happy Swimming~
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
    Apr 2010
    Buckeye, AZ 85326
    619
    Re: Harsh water
    Thanks for all the responses.
    Here are my numbers from this morning. My test results have been pretty solid everyday. The water is clear and sparkly.
    I'm using the "Deluxe Poolcare DPD Test Kit"
    FC 3
    TC 3
    CC 0
    pH 7.5
    TA 90
    TH 250
    2' Powerfall
    22,551
    Re: Harsh water
    Thanks for the numbers.
    Do you know what your CYA (stabilizer) is?
    Apr 2010
    Buckeye, AZ 85326
    619
    Re: Harsh water
    The test I have doesnt do CYA? Unless there is a dropper combo that will work but isnt on the directions. When I had the water tested at Leslies they said CYA was good.
    2' Powerfall
    ssa's Avatar
    San Jose,CA
    26
    Re: Harsh water
    It is very important to keep track of your CYA level.
    Leslies should give you a sheet of the test result, there is a column said CYA.
    It is always a good idea to get yourself a TF100 like test kit which you can test CYA
    yourself.
    15x32 vinyl, IG,17K gal, DE filter, Hayward 3/4 HP pump, Hayward Ultra Vac, Solar cover with reel
    SportCount LapCounter, FINIS SwiMP3.1G
    Enjoying my pool thanks to TFP.com
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Harsh water
    Pool stores are notorious at doing the CYA test incorrectly. You really, really need your own good test kit. It is THE most important investment you can make for pool maintenance.
    ssa's Avatar
    San Jose,CA
    26
    Re: Harsh water
    Quote Originally Posted by chem geek
    I second that. I have fresh filled water bring to two leslies at same time, one test 0 CYA the other one 30.
    I seems that which individual test your water matters a lot of the out come.
    The good store staff consistently give me good test results that match
    my own test.
    I did not buy my own test kit until recently. I feel it is kind of expensive because I
    can always get it test free. Now I am glad I did. Actually, I wish I get the TF100 delux
    because chlorine and CYA is what I care most. Chlorine need to monitor closely
    and CYA used a lot to do one test.
    ssa's Avatar
    San Jose,CA
    26
    Re: Harsh water
    BTW, some leslies people will skip the CC test and just write zero or 0.1 if you tell them your water is clear.
    I am watching them and try learn how the heck can they do the water test that fast.
    Some of it is good skill and some of it is, hmm, you don't want to learn those any way.
    CC is likely what cause your chlorine smell.
    Apr 2010
    Buckeye, AZ 85326
    619
    Re: Harsh water
    Allrighty I called Leslies and found out my CYA was 40 the day before the party, if the person behind the counter did it correctly
    So
    FC 3
    TC 3
    CC 0
    pH 7.5
    TA 90
    TH 250
    CYA 40
    thanks
    2' Powerfall
    ssa's Avatar
    San Jose,CA
    26
    Re: Harsh water
    If your CYA is really 40. The number looks good except that FC is a little bit on the low side.
    For CYA 40 your FC min is 3. Max is 5. So you might want to raise your FC to some thing close
    to 5. Especially you just have a party. Do an over night FC loss test and see if the FC drop
    more than 1ppm over night.
    Still not sure about the dry itchy skin though. Well balanced water should not cause that.
    Did you have your pump run a while before the water sample? You want the water well
    mixed for testing.
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Re: Harsh water
    Again, I feel I must say that just because somebody said they had dry itchy skin does not mean that there is a darned thing wrong with the OP's pool water. People can be odd; their bodies can be odd, and they can say odd things for odd reasons.
    I do encourage the OP to buy a knockout test kit and to come to be very familiar with the joys of having a firm, confident handle on exactly what is going on in one's own pool/water. Knowledge is bliss.
    Lana
    Apr 2010
    Buckeye, AZ 85326
    619
    Re: Harsh water
    Thanks again for all the replies. I think I'm going to have to side with Lana. The numbers dont lie. I'm still getting used to the pool calculator and all the chemicals. This site sure is a big help and confidence booster.
    2' Powerfall
