Thread: Intellitouch Controller Problem
    I have a 3-year old Pentair Intellitouch I9+3 pool sytem controller. The 12V (Electronics) low voltage circuit breaker in the load center tripped this weekend and will not stay reset. Hence I have no control over my system. The Pentair literature offers no help that I can find regarding how to diagnose the problem. Can anyone offer any advice on how to diagnose the source or fix the problem? Is there a way to run my Intelliflo pump manually while I try to fix this problem? Thanks.
    South Central NJ
    3,192
    Re: Intellitouch Controller Problem
    Sounds like the transformer took a hit and shorted or the AC to DC converter on the board went.
    Scott
    Owner of - PoolGuyNJ LLC
    Scott - Thanks. I suppose I can measure the output voltages on that leg of the transformer fairly easy to check that possibility out, correct? Is my only option on the AC to DC converter problems to replace whole board? Charles
    South Central NJ
    3,192
    I would expect so. I don't think the bridge rectifier is socketed. I expect it's the transformer though there is a possibility it took the board with it as a daisy chained event. Had any lightning storms lately?
    Scott
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,694
    Try unplugging all the valve actuators from the board, and see if the breaker will reset.
    Factory Warranty Station for:
    Pool Clown - I'll try unplugging actuators too. Thanks, Charles
