Results 1 to 12 of 12
Thread: hit it hard
    May 2009
    Trenton NJ
    497
    hit it hard
    I opened my pool yesterday and it looked like a swamp,so I shocked it pretty hard with about 15 gallons of liquid chlorine in about 2-3 hour intervals.
    This morning,the water was just a little cloudy, which is great, no more green. I have the FAS-DPD test kit, here are my results:
    fc-12.5
    cc-.5
    ph-8 plus
    ta-80
    ch-130
    I need to buy more reagent to test for cya
    My question is did I shock too much too fast. I read that if chlorine levels are too high it could damage the equipment. I never got hold of the algae this fast, was hitting it with that amount of chlorine so fast a bad idea,should it be more gradual?
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: hit it hard
    Without knowing your CYA we can't tell if you raised the FC too high. Usually it doesn't hurt to have high FC over a short period of time. Get your CYA tested as soon as possible so we can determine what your shock and normal FC levels should be.
    Love TFP? Become a
    TFP Supporter!
    Re: hit it hard
    While you are working on finding out the CYA level, you should bring your PH down to around 7.5.
    May 2009
    Trenton NJ
    497
    Re: hit it hard
    Well bad news, I did have some reagent and tested for cya. I went all the way up to 30 and it just was starting to get cloudy,so the cya is very low.
    Now what? Do I need to drain and add water? It supposed to rain tonight.
    I do have another question, when you aerate, does the ph go up or down?
    Thanks
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: hit it hard
    aeration causes PH to rise. If your CYA is low, you do not need to drain, you need to add more CYA
    May 2009
    Trenton NJ
    497
    Re: hit it hard
    Oh one more thing I did drop off some water to be tested at pool store to just compare numbers. The fc result was the same but they tested for cya and they got 90.
    I've done this test many times last summer so I know I didn't make any mistakes, how could there be such a difference?
    Re: hit it hard
    If in fact your test went to 30 cya before it even started to get cloudy then there is no way I would trust a reading of 90. The store may have mixed up your ta numbers with cya )
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    Butterfly's Avatar
    South Carolina
    10,045
    Re: hit it hard
    I agree, always trust your test numbers over a pool store.
    You're done SLAMing when:
    May 2009
    Trenton NJ
    497
    Re: hit it hard
    I know when you add stabilizer you are not supposed to backwash for 3 or more days, correct? What do you do at this stage when opening a pool and you constantly need to backwash? Do you wait a few days to add the stabilizer and keep on backwashing when needed or get the stabilizer in asap?
    I remember reading here that some of you put the stabilizer in a sock and hang in front of one of the returns for about a week or so?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: hit it hard
    If you use a sock, backwashing is not as bad, but it will dilute your anticipated CYA level. Not backwashing is far more important if you still happen to add CYA via your skimmer (not something we recommend) and it sits in your filter undisolved...backwashing would then flush most of it to waste.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: hit it hard
    Quote Originally Posted by ethany
    Recommend not to back wash for about a week when you add the stabilizer thru your skimmer.
    You need stabilizer asap.
    Yep, put it in a sock and hang it in front of a return.
    It will probably be dissolved in a day or two. It will dissolve faster if the pump runs 24/7 and you squeeze the sock several times a day.
    May 2009
    Trenton NJ
    497
    Re: hit it hard
    You guys are the BEST,I am so glad I found this site. I am out of work now but as soon as I find something I am looking forward to becoming a formal member.
    Thank you
