Results 1 to 12 of 12
Thread: So gross-Waiting for circulation to start shock and balance
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    We need about 3" more water to get the pump running then it's time to ZAP this water but good - isn't it gross? I used to have an old pump and filter I could set up temporarily with hoses over the side while I filled/topped off at startup each spring so I could shock the you-know-what out of it and never have to see this - but alas - we got greedy and sold it on CL - now I wish I hadn't - yucky! The delays with weather, parts and reliable help around these parts resulted in the water becoming the mess you see before you. Give me a couple of days and all will be well with the world again and we will be back to the sparkly water I'm used to - but I do have to say, the new liner is not nearly as pretty and doesn't give the water the pretty Bahamas Blue look we used to enjoy. Oh well, I'm happy to HAVE a new liner and finally water in there to actually clean and look at!! My TF100 kit is ready
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    Re: So gross-Waiting for circulation to start shock and balance
    It looks like a Baquacil to chlorine conversion with that green color. Good luck!
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    Feb 2010
    Houston, TX
    271
    Mmm...pea soup! That's making me hungry!
    All kidding aside, at least you know how to get it clear without stepping in a pool store! Can't wait to see it sparkle!
    John
    24' round Vogue AGP 12,000 gal. Flotec AT251001-01 1HP pump, Hayward S310T2 sand filter, Aquarite SWG T-15
    TF-100 (found at TF Test Kits) with Speedstir and Samplesizer
    I honestly dont see the problem here. You have your test kit, this very cool website and you know how to use both. I would use this time to go get some bleach and put on a pot of coffee , you may need both.
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Grrrr - waiting for the water level to get high enough we decided to saddle up the horses and go riding - it would be good to go when we got back. NOT, my kids shut the water off right after we left. For Pete's Sake!!!! I so want to turn that pump on as I'll be gone to work from 6am - 4:30pm tomorrow. I guess I'll be up late tonight to be sure it goes.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,731
    if I recall correctly, I think you have a pool rover jr? You could just run it without the bag to get the water moving and add bleach
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Yep, Mo is running out there as we speak. It does help circulate but you guys know me - I have no patience!!
    It's gonna be a challenge, but keep at it. I'm sure it will be clear in a week or two!
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Quote Originally Posted by denisbaldwin
    Oh it won't be nearly that long. Good shock plan with 24 hr circulation and it will be clear by the weekend. The pump has been running since 10pm last night - we are headed to get more bleach since it's raining again anyways. I shocked with 1# dichlor yesterday to add some CYA with PRJ running then last night with 1.42 gals bleach, shocked at 4:45 this morning before work with 3qt bleach as it was all I had left so heading out for more. Water has gone from green swamp to a clearish green tint and we can see the bottom nicely.
    On a side note - this rain is NEEDED to aerate and get the PH up so I can dump acid in - my PH was already down at 7 but the Alkalinity is over the top as usual. I won't have to use my well to top off the pool those last couple inches anyway since it's monsoon season here.
    9:30 pm - wowie - RAIN - another 2" fell into the pool since we we went to Walmart at around 6pm- it filled it up even more and I'm sure gave the added benefit of the aeration I needed! I just put 545 oz of 6% bleach in - not much change to the pressure on the pump so I'm not going to backwash until that starts to drop. I think I may dump a bit of DE in to catch some additional stuff as long as it has a ways to go on the pressure yet. I'll dump another 128oz bleach in just before bed and hit it again at 4:45 tomorrow morning before work. My yard is a swamp from all the rain and I'm a bit hesitant to stand out there ankle deep while it continues to thunder and lightening. Gee do you think Crocs are good insulaters??
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    So the pool is now a fairly clear light bluish green color - I've backwashed umpteen times to dump the junk which was nasty dark iron colored- I suppose a combo of the sequesterant gunked with iron and some algae. I've been super shocking a number of times each day, using DE in the filter right after each backwash, brushing and running Mo - our Pool Rover. The salt went in yesterday morning and the Aqua Rite is happily operating now at Super Chlorinate. I messed around working on getting our Alkalinity down. The water temps are creeping up from my 54 degree fill temp the other day to 71 now. I'm hoping we have something even prettier to look at by the weekend or Sunday.
    I have read here that it is not recommended to use the SWG at Super chlorinate level as it uses up the cell too fast, that it is more economical to use bleach to get the chlorine boost and just use the SWG to maintain levels. But wait for better advice on that.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    I generally have followed that advice for the last few years except when we going out of town. We are in fact going out of town until Sunday and we live 20 miles from town - nobody to add bleach while we are gone. It probably won't use up too much of the cell for just a couple of days.
