Thread: Pool opening readings
    Aug 2009
    Central New Jersey
    14
    Hi! All! Started the BBB method last year and love it! I opened the pool for the first time and the water is clear but I need help with my readings as I'm a little confuse as what to add to the pool. The readings are as follows;
    FC 0
    TC 0
    CC 0
    PH 7.2
    TA 100
    CYA 0
    Temp 64
    I added these readings to the pool calculator and the results don't seem right. Please help, I need to know how much to put in there and of what to have a perfect swimming season. I really appreciate it. Looking forward to great results!
    12,600 gallons
    Cartrige filter
    1 hp pump
    24x18 Above Ground Oval
    30,419
    Re: Pool opening readings
    You need to get chlorine and CYA in the pool right away.
    I would start by adding 1/2 of a small jug of clorox each evening for the next 2-3 evenings or so.
    At the same time, add enough CYA to get to 40-50ppm.
    After the 2-3 evenings of adding chlorine, test again and post your results. You only need to test for.....
    FC
    CC
    CYA
    Your pool should stay clear since it's already clear but get the chlorine in their absolutely right away.
    Please do not take this as a scold but rather further explanantion of BBB. BBB is about knowing how to test accurately and knowing what to do with the test results. Do not rely on the pool calculator to maintain your pool. You need to apply the knowledge you are gaining from reading pool school and apply that knowledge to your test results.
    We all started with zero knowledge of pool care so all of us will help with any questions you may encounter but we want you to be in charge of your pool thru testing and knowledge.......the pool calulator is only another tool to help you manage what you have learned.
    Aug 2009
    Central New Jersey
    14
    Thank you so much for your response, I will do that!
    12,600 gallons
    Cartrige filter
    1 hp pump
    Aug 2009
    Central New Jersey
    14
    Is now 8 days later and my pool is crystal clear, I took pictures under water of my son and and you can see from one side to the other, is amazing! My readings as of yesterday were as follow;
    FC 5
    TC 5
    CC 0
    PH 7.6
    CYA 40
    Thank you so much for your help, I really love this site! I can't stop talking to my friends about it, but they don't listen, I guess they refuse to save money , oh well is their lost!
    12,600 gallons
    Cartrige filter
    1 hp pump
    30,419
    Yeah, most all of us have experienced that, too. We take quiet retribution by comparing their pools to ours!
    Very nice work on your pool water!
