Thread: opening pool w/ swg
    opening pool w/ swg
    We opened our 18' x 52" aboverground pool yesterday and filled it to the right water level. We are using the intex saltwater generator model 8110 which was set up last year and worked great. I always forget to write down how i open the pool so I can remember the next season.
    These are the numbers I got when I checked the pool yesterday with the TF-100. I'm afraid to add anything before I ask. I used the pool calculator.
    FC 3.5
    CC .5
    TC 4
    pH 7.2
    T/A 70
    CH 100 (doesn't matter because its a vinyl pool right?)
    CYA 50
    salt 2070
    The calculator said to add 50 lbs of salt to bring it up to 3000 ppm, 46 oz of baking soda, and 15 oz of borax. Is this right?
    22,544
    Re: opening pool w/ swg
    If this is new fill water it'll take 24 hours for the salt to register. If it's not new water, just raising the level, then the only thing I'd add right now would be the salt. Your pH is in the acceptable range and with a SWCG it's gonna raise anyway. Your TA is good and it'll lower as you adjust the pH. You're right about the CH.
    Just raise the salt to 3000 and CYA to 80 and leave PH and TA alone. The PH will drift up slowly on it's own. And TA around 60 to 70 is good with a SWG.
