Results 1 to 7 of 7
Thread: Pool pump size
    Jul 2007
    Suwanee, GA
    528
    Pool pump size
    Pool experts:
    I know this topic has been beaten to death at times and I’ve searched the usual places for answers, but nothing I’ve found has really set me at ease.
    My PB has installed a 1HP pump for my new pool (still under construction) and I was originally a bit upset about this and I was going to request a larger one. I've done a bit of reading that may have changed my mind, but the more I read about bigger is not better, I also find that smaller is often not enough. Anyway, think I’m ok with the smaller pump, I’d just run it longer and it will save me a bit of $$$, but I’m no expert and some other opinions would be nice.
    The pump is a 1hp Jandy Stealth with a 2” pipe to the returns where it T’s of into 2 - 1 1/2” pipes for the returns (2). 2 – skimmers with separate 2” piping back to the pump and one main 2” main drain. I’d say about 30-50’ of piping (from pump to pool).
    I don’t know my gallonage, the pool is roughly a 16x38 or so, 3 1/2 to 7 1/2 feet deep.
    No water features, the slide has a separate 2hp pump, all plumbed separate and there is a 3/4 HP booster pump for the cleaner, return on the cleaner is 1 1/2 inch.
    I know you're going to ask about the filter, but I don't have the specs with me at the moment. I know it's a Jandy CL series, not sure about the size.
    I’ve got another payment due soon, so now would be the time to bring it up if it will be an issue.
    TIA
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    That's plenty of pump. You could probably get by with a 3/4HP pump.
    That pump should be just fine. If that is the 1 HP full rated version you could even go a little smaller. You could also opt for a two speed pump to save electricity and still have high speed as an option. As long as you are only using the pump for normal circulation, you only need a small pump.
    Jul 2007
    Western East Texas
    40
    If it's still possible, go with the 2 speed pump. Your wallet will thank you many times over.
    5450 gallon 18' Intex Easy Set, Dynamo 3/4 hp 2 speed pump, 200# sand filter, Intex swcg, k-2006 test kit
    Jul 2007
    Suwanee, GA
    528
    Thanks for the info guys. Perhaps I'll go with the two speed in the future, I need to save the rest of the budget for things like water...
    Gary
    Jul 2007
    Suwanee, GA
    528
    One more question.
    What's with the 1" flexible hose for the booster pump and wimpy looking clips? Why didn't they just use the rigid pipe with the unions as with the other pumps? Just seems like a point of failure.
    Gary
    ktdave's Avatar
    Katy, TX
    888
    Quote Originally Posted by crabboy
    One more question.
    Good question. That is exactly how my booster pump is plumbed (new pool).
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
