Thread: Twist Lock Plug Vs. Hard Wire
    Hey everyone,
    My electrician just told me that it meets code in our area to use a Twist Lock Plug for the pool pumps. So I have a choice, Twist Lock or go for the Hard Wire. Any reason why Twist Lock is not as good as the Hard Wire?
    Thanks!
    18 X 36 In-Ground Vinyl Pool, Hayward 1 HP SuperPump, Hayward SP270T 350lb Sand Filter, CompuPool CPSC48 Salt Chlorine Generator, Hayward H400FDN 400 BTU Natural Gas Heater, 2 returns, 1 skimmer, No Main Drain
    Re: Twist Lock Plug Vs. Hard Wire
    Twist lock is nice if you take the pump indoors for the winter. Hardwire is more reliable and just slightly safer.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    I think I'd prefer a twist-lock. Then I'd have a convenient source of 220V out back. I have no plans now, but someday I may need to plug in an air compressor or a welder.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Null, as long as it meets code, go with the twistlock!!
    If you want some of the reasons, simply ask.
    Luv& Luk
    -Ted
    Thanks! Electrician has been notified
