Thread: Leaking filter help and replacement suggestions
    Apr 2009
    Marietta, Georgia
    3
    We noticed last night that the filter at the house we're renting was spraying a fine mist of water out through a half-inch crack in the side (probably from unexpected hard freeze last winter around here where people don't winterize their pools). The landlord would like to spend less than $600 replacing the filter (including labor which runs $250 here for filter installation if you buy from them).
    Leslie Pools just sent a flyer in the mail with a coupon good only this weekend for 10% off all equipment and 25% off Hayward equipment. What would be a recommendation for a good budget sand filter that would match up to the pump that we have?
    Also, what would be the best thing to do for the filter tank to stop the leak until we get the filter replaced?
    20K gal vinyl in-ground
    Jacuzzi Magnum Force single speed pump 1.5 HP, 1.65 SFHP
    Jacuzzi Laser sand filter 250L, 25", 3.3 sqft, 83 gpm (25 gpm/sqft), 350#
    Polaris 360
    Re: Leaking filter help and replacement suggestions
    The Pentair Sand Dollar SD 80 or Hayward Pro Series S270T are both good choices.
    Changing a filter is not really that complicated. If you are familiar with piping in PVC then I would save the 250.00 and order online.
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
