Thread: DE question
    DE question
    Hello. I am somewhat of a novice and was hoping to get some help with my DE filter. It is a 48 cu ft stainless that says on the side to add 10-1 pound coffee cans of de. Does this mean 10 pounds? I bought a 10 pound bag of de, but am hesitant to add because I just cleaned it all out. Any help would be appreciated. Thanks!
    18x36 (~20k gal) Gunite w/fiberglass walls, Sand filter, Polaris 380
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Re: DE question
    Quote Originally Posted by JRH13
    NO!! Stop!!
    I hope I caught you in time. DE is less dense than coffee; it's the volume of a 1 lb can you're interested in, not the weight of the contents.
    If I wasn't in such a hurry to post this, I'd look up the weight equivalence.
    no-mas's Avatar
    Jun 2008
    FL
    405
    Re: DE question
    Quote Originally Posted by Richard320
    ....If I wasn't in such a hurry to post this, I'd look up the weight equivalence.
    Roughly 1/2 pound DE per 1 lb coffee can. You should add 5 lbs of DE to your just cleaned filter.
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: DE question
    Most pool stores will sell a DE scoop that gives the correct "1 lb can" volume. I would not trust measuring by weight.
    Love TFP? Become a
    TFP Supporter!
    Jan 2009
    Cupertino, CA
    1,966
    Re: DE question
    Also I have yet to find an actual 1-lb coffee can at the grocery store. They're all 14 oz now. The DE scoop is really the way to go.
    --paulr
    BBB "Intermediate Swimmer"
    Re: DE question
    Thank you all for the replies. I am about to add the DE now and would have put twice as much in than is needed! Thanks again.
