Results 1 to 11 of 11
Thread: shocking please help
    Shocking once again tonight. Have some questions
    1st Shock #'s
    PH 7.5
    FC 12.5
    CC 1.0
    TC 13.5
    CYA 70
    Did calculator added 4.1 jugs tested
    2nd Shock
    FC 37.5
    CC 1.5
    TC 39
    Now what just wait for another hour and test again until CC is .5?
    Tnks
    16X32 Rectangular In Ground Built 1998, New Vinyl liner and Motor 8/2012, 19,000, Hayward Sand Filter, Hayward Super Pump,PoolPilot DIG-220 SWG, 2 Skimmers, Main Drain, Clean Machine Robot, Full Sun, Bleach, TFTest Kit
    Central, VA
    22,553
    Re: shocking please help
    Yes wait an hour and test and add.
    Read Pool School on how to shock, especially the part on knowing when you're done.
    Keep at shocking
    till the CC's are .5 or less,
    You lose 1 or less on the overnight chlorine drop test.
    And the water is clear, if you don't have a FAS-DPD test kit.
    Thanks using a FAS-DPD test kit received yesterday. Algae is still present at 1.5 correct?
    Central, VA
    22,553
    It actually means that the chlorine is killing organics which is most likely algae.
    Thanks took another reading FC 34 CC 1.5 still will continue. Hope to see sparkly water tomorrow
    Central, VA
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    sunlight will help burn off the CC's tomorrow...you should see a lower number late afternoon
    do i continue to ck tonight or wait till 6 am and ck and add
    Central, VA
    May 2009
    Jasper, TN
    249
    It's way late for your question, but I just wanted to mention, at a FC of 37, you're WAY higher than needed shock levels. You only need to keep it at about 20-25. Anything higher and I'd be afraid of the liner fading.
    24' x 52" AGP = 13.5k gallons
    Dynamo 2.0 HP pump,Sand Dollar sand filter
    Polaris 65 vacuum (good when there are a ton of leaves on bottom), Pool Rover Jr. (LOVE it, but power box dead right now), AquaCritter (an excellent suction side cleaner)
    Thanks maybe i didn't do the test right........ Staying today around 28 w/CYA of 70. Getting better adding less and less chlorine. Still have CC1 waiting for the magic .5. Thanks for the input.
    Central, VA
    Butterfly's Avatar
    South Carolina
    10,045
    How does your water look?
    You're done SLAMing when:
    Still shocking today adding less and less chlorine but can't break the CC1. Still a little cloudy I need to vacuum raining today and tomorrow. But I'm still running the numbers hope to see the sparkle tomorrow Once i have CC.5 i will re check the other numbers and see if I need to make any other adjustments. Thanks for asking
    Central, VA
