Thread: Older pool and SWG question
    Souh Florida
    2
    I live in South Florida, have an older 15x30 in ground pool (about 30 years old) with brick coping (seems to be ordinary rectangular red brick) and Kool deck on the rest of the patio. The pump is the same age jacuzzi. I'm considering salt and looking for opinions on how this material and equipment might hold up. I've tested the salt content for grins and it's already at 2000 PPM from just using liquid chlorine over the years. Any opinions?
    Oct 2007
    Valrico, FL
    542
    Re: Older pool and SWG question
    I love my SWCG. I don't think that age of pool has any bearing on suitability. You do need a straight run of return in order to place the cell and flow switch.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    a swg produces chlorine gas which then mixes with the salt water to make pretty much the same thing as liquid chlorine, so if you have been using liquid chlorine then swapping over to a swg should be ok.
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    I think the OP is concerned about using salt and possibly a higher concentration (3000+ ppm). Shouldn't be a problem and you could always use a brick sealer as an added precaution.
    Souh Florida
    2
    Thanks for the replies. dmanb2b is correct. I know there have been reports of salt damage to softer natural stone and I was wondering if anyone has any experience with it's effect on brick coping.
