Results 1 to 13 of 13
Thread: "test kit questions"
    Just received new test kit having problems. Numbers seem to be off. When testing CH turns purple not red after adding R0011L and after adding 30+ drops never turns blue. Tried 3 times? when they say rinse out tubes is that in the pool or the tap water. Maybe they are not clean just rinse and wipe dry? Seems like a dumb question sorry. How many times in the evening can you shock? I do it once according to calculator, ck FC level and wait to morning to ck again. Have shocked for days.. Still CC of 1.5 and cloudy water. Have gray dead algae in the skimmer guess I should shock again tonight.
    This morning after shocking last night
    FC 21.5
    CC 1.5
    TC 2.2
    TA 280?
    PH 7.8
    CYA 60
    CH
    At a loss how many times in evening to shock is at the right level? Cloudier today after shocking?
    any help would be great very down trying for months for the sparkle!!
    16X32 Rectangular In Ground Built 1998, New Vinyl liner and Motor 8/2012, 19,000, Hayward Sand Filter, Hayward Super Pump,PoolPilot DIG-220 SWG, 2 Skimmers, Main Drain, Clean Machine Robot, Full Sun, Bleach, TFTest Kit
    Central, VA
    Re: "test kit questions"
    Drop your PH to 7.2 by adding muratic acid ( consult the pool calculator.) This should also help drop your TA somewhat. Your chlorine numbers as posted are wrong. FC+CC=TC Please re-check your notes or retest. Post your results again when you can. Water is likely cloudy due to high amount of dead algea. Brush pool walls and floor to expose new algea to chlorine. check sand filter for preasure and back wash as needed. Keep pump running 24/7 while shocking. What are you using to shock the pool?
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    Thanks I see #'s are wrong. Brushed, and back washed pump running 24/7. Using chlorine to shock. Could PH be off due to high chlorine level after shocking? Any answers for the testing of CH? use pool water to clean out vials?
    Central, VA
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    FC levels above 10 can affect Ph readings, yes..but I'm not sure of your FC level the way you have it listed. If it's below 10 then I'd say you can adjust your ph, but if FC is above 10 leave alone and keep shocking.
    I always rinse my vials with freshwater from the hose or sink and wipe with a soft cloth or paper toweling.
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Quote Originally Posted by koliver13
    Just received new test kit having problems. Numbers seem to be off. When testing CH turns purple not red after adding R0011L and after adding 30+ drops never turns blue. Tried 3 times? when they say rinse out tubes is that in the pool or the tap water. Maybe they are not clean just rinse and wipe dry? Seems like a dumb question sorry. How many times in the evening can you shock?you can add chlorine to reach your target shock level as often as once per hour. Just keep putting in the current and the target into the calculator and add what it says. The more often you add to shock level the more quickly you will be done shocking. Shocking is like antibiotics...if you don't continue the dosing until it's done then you just keep having a bit of stuff to fight off. I do it once according to calculator, ck FC level and wait to morning to ck again. Have shocked for days.. settle in for a late night, make some coffee and keep hitting it hard all night. Still CC of 1.5 and cloudy water. Have gray dead algae in the skimmer guess I should shock again tonight.
    FC 21.5
    CC 1.5
    TC 2.2
    TA 280?
    PH 7.8
    CYA 60
    CH
    You'll get there..
    Ok, FC 21 was after shocking last night. will continue to shock and leave PH alone for now. Thanks for advice on cleaning tubes. this is taking forever and I'm loosing my patience. If I've raised my FC to shock level tonight wait till morning to check FC and CC again?
    Central, VA
    Just read your other response keep it up to shock level as long as I can to reach CC of .5 or less?
    Central, VA
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Yep. Read this article, it will be helpful. Also, it doesn't hurt to read and re read pool school...
    http://www.troublefreepool.com/pool-...king_your_pool
    Post back with any questions and some one will help. If you'll post your current FC and CC level I can plug it in to the pool calculator and double check that you are on the right track.
    Thanks read and re read just didn't have the clarity that I needed. I'm slow..... At work will try again tonight I've been using the calculator thanks so much think I have it now. waiting for the sparkle
    Central, VA
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    You are welcome. Someone's always here to help...
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    If CH is really high, use 10ml sample instead of 25. Straight from Taylor:
    * When high CH is anticipated, this procedure may be used: Use
    10 mL sample, 10 drops R-0010, 3 drops R-0011L, and multiply
    drops in Step 4 by 25.
    Another thing to try is to add 3 or 4 drops of R-0012 before you start the test. Swirl it good, then add R-0010 and so on in the usual manner. Just include the initial drops in your count. That can help with the colors.
    Butterfly's Avatar
    South Carolina
    10,045
    TA 280?
    Sometimes static is a problem with the test. Try wiping the dropper with a damp cloth between drops.
    I rinse tubes first with tap water and then with pool water.
    You're done SLAMing when:
    Thanks for both those tips I'll try those methods. This is a great place
    Central, VA
