Thread: Hawkfan Washington State
    Washington State
    I am from Washington State and just sold my Lomart 18' x 48" (just too small for family) I am currently looking for a new above ground pool. I have been leaning towards the new intex soft sided ultra frame pools because of its easy setup and low price. I dont know much about them and I dont know anyone that has one so my research is limited. I did like the metal sided lomart which was very sturdy and we didnt have any problems other than the liner needing to be replaced so I am sorta stuck on what to do any advice would be much appreciated.
    Thanks and Have a Great Day!!
    24,000 gunite freeform w/ pebble plaster, weeping wall, spa; Pentair Cartridge Filter; 2HP Whisperflow pumps; inline chlorinator
    Feb 2008
    Flower Mound, TX
    Re: Hawkfan Washington State
    Welcome to TFP!
    10K gallon IG gunite with waterfall; Pentair CC320P filter; WhisperFlo 2 HP pump
    TF Test Kits - Pool Math - Pool School
    "It depends."- JohnT
    Butterfly's Avatar
    South Carolina
    Welcome to the forum
    You're done SLAMing when:
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    Welcome to TFP!
    As you can see, I have the Ultra-Frame, we love it, wish that they had come out with the 24' last year!
    The only issue is you have to set it up and take it down every year.
    Not to much work, it takes me about an hour to setup, 1/2 hour to get the floor smooth while water is flowing in. I think that it will take another hour or 2 to get all the plumbing hooked up.
    So basically, it will take a full Saturday start to finish with a few breaks.
    Tear down is the about the same amount of time plus time to dry - a full Saturday start to finish. Drain, unhook the plumbing, spray down the inside and wipe, put the pool up on lawn chairs (one chair per leg) spray down and let dry.
    I think it takes about the same amount of time for opening and closing a perm. pool but as a former perm owner you would know.
    Cost - Walmart has the 24' on sale for 699.00 darn cheap for a 24' considering I paid 600.00 for mine last year (with out the pump and junk) and it is an 18'.
    Plus you would need a pump and filter cause the combo that comes with the pool is worthless.
    Figure another 3-400 (or less if you can find a used one somewhere). (Not sure on what a 24' perm would be, never checked into but there is a lot on Craigslist used.)
    Good luck with your decision
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    Mar 2009
    eastern washington state
    welcome hawkfan, I am from eastern washington state, Moses lake; I have had my pool going for 2 months now... thanks to a very good heat pump...
    live in eastern washington state
    18x36, Vinyl inground 24k
    Hayward 1 hp filter pump
    1 skimmer/2 returns
    24" sand filter, polaris 280 with booster pump.
    Welcome, Hawkfan. I'm from western Washington, Olympia, my pool is up, but it's still too dang cold to jump in yet. We should have some warm weather here by, maybe, late July...
    33000 IG vinyl pool
