Results 1 to 9 of 9
Thread: Here is what we have so far
    I am using the TF-100 testing kit
    FC: I added my water to 10ml mark, added my heaping scoop and swirled... it never turned pink???? Does this mean I have no FC?
    Couldnt finish the rest of the test 'cause it never changed color to be able to test for CC
    CC: See Above
    TC: See Above
    PH: 7.5
    TA: 90
    CYA: 25 ( just added some tonight, this is not a true reading )
    Added my stocking of CYA, should I adjust my TA?
    We don't have the filter running yet, but we do have the pump running.
    Lori
    21,200 Gallon AG Sand Filter
    30,403
    Re: Here is what we have so far
    Yes, you have 0 FC. It is important to get some into your pool. I don't know how your water looks so, for now, I would put in a small jug of clorox tomorrow AM (or ASAP) just to get some protection in your water.
    Disregard your TA of 90...it's just fine.
    Why isn't your filter working but your pump is?
    Post back and tell us how high you intend to get yor CYA and we'll help you get your FC up where it needs to be. Chlorine is consumable and will always need to be added to your pool. You do not want FC to be at 0 ever.
    Sorry for lack of information.
    Just started the pool, 3rd year... we are green and full of algae.
    Tested at first and PH was high... well over 8.2
    Got that lower, now we're ready to start with the bleach cya etc.... I didn't want to start the filter if I had to backwash, with us just adding the cya... didn't want to waste it.
    But I did want to get it circulating... I will start the pump tomorrow... along with bleach if thats what you recomend.
    I have a 21,200 gallon AG pool
    Does 40 sound like a good place to keep our CYA? Or should we go higher?
    Thanks for your help!
    Lori
    30,403
    Hi, Lori,
    That's a much better picture of your pool. You need to shock your pool.
    I would not add any additional CYA until your shock process is complete. Please read "How to Shock your Pool" in Pool School. Also ABC's of pool water chemistry in pool school will shed some light for you.
    Shocking your pool is a process of very high chlorine levels, brushing and vacuuming and, importantly, filtering the dead algae and debris from your pool You will have to run your pump and filter 24/7 and you will have to put a ton of chlorine in your pool.
    Read those articles, ask questions, and stock up on bleach....everything else can be done alter
    Hi, Lori,
    So it is OK that I added the CYA tonight?
    Here are my plans for the morning....
    Starting the filter
    Dumping gobs of bleach... I have 17 gallons as of now, and some "shock" that we bought last year before we learned that it was a verb not a noun (TeeHee)
    Scrubbing and vaccuming
    Backwashing when needed
    Repeat
    Where should I get my shock levels to since I am not 100% on my CYA yet?
    Lori
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by LoriLeeMcD
    Just assume it's all dissolved. If you put in enough to get 40, use 40 for the calculations. Next week you can test CYA and see what you really have and use that.
    Mar 2010
    Spring, TX
    1,082
    If it were me, I would avoid putting in the shock and just use the bleach to shock the pool. The shock may add other stuff that you may not need.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    This is at 11am Dumped in 4 bottles of Bleach with a reading of 0 FC
    This is at 1pm dumped in 3 more bottles with a reading of 5.5 FC 5.5 CC
    So we are getting somewhere ... shooting for 16 FC
    Lori
    Mar 2010
    Spring, TX
    1,082
    Huge difference. Nice work keep it up.
