Results 1 to 20 of 20
Thread: How should I pour the bleach?
    Apr 2010
    Central NJ
    227
    So last night I did my first test with the TF-100 and got the numbers below. I went to the pool calculator and it says to add 16 gallons of bleach. From what I understand I should pour it in front of one of the jets, what I haven't found anywhere is how. Should I just put the jug on its side? Would that be too fast and too splashy? Can my son and I pour at the same time on two different jets? Any tips would be helpful as I plan on pouring it in tonight.
    FC .5
    CC .5
    TA 120
    CH 90
    CYA 70
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    Feb 2008
    Denton, TX
    5,061
    Re: How should I pour the bleach?
    Sure, you can employ your son here. Each of you find a return jet at opposite ends if possible. Open up the bottle and pour slowly enough so as not to splash, directly in the return flow so that the returns carry the bleach out into the water.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Some of us float the jug part way in the water...it helps suspend some of the weight and gets the mouth closer to the water, so less splashing.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Apr 2010
    Central NJ
    227
    Thanks! This site is great....it's definitely worth its wieght in.....bleach!
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    I like the cut of your jib! (you'll fit right in )
    I just walk the perimeter of the pool, pouring at ~ waist height, but then again, I ruin a LOT of pants each year doing it that way
    Luv& Luk
    -Ted
    Mar 2007
    San Rafael, CA USA
    12,082
    It's usually a good idea to pour most concentrated chemicals, including bleach or chlorinating liquid, slowly over a return flow at the deep end with the pump running. For extra safety, since you have a vinyl pool, you can lightly brush the side and bottom of the pool where you've added the chlorine to ensure thorough mixing. You don't want any chlorine pooling at the bottom of the pool -- once mixed, however, chlorine stays mixed.
    Just note that bleach and chlorinating liquid will bleach your clothes with even the smallest drop so be careful. I usually change my clothes to a pair of jeans that is getting more and more white spots from all the accidental drops over the years. No matter how careful I try to be, every few weeks or months I seem to screw up. Putting the jug or cup into the pool for pouring should minimize the problem, but rinse your hands in the water afterwards in case something spills on them.
    Apr 2010
    Central NJ
    227
    so i shock the pool last night and now I do another test (8 hours later) and I get the same numbers I got last night:
    FC .5
    CC .5
    I'm heading out to get more bleach, but I'm getting worried that I'm not doing the test correctly and I might "over bleach" my pool, if this is even possible.
    BTW: the pool was a little cloudy last night, this morning it it's much clearer.
    Mar 2010
    Spring, TX
    1,082
    From what I have read on here, if it is clearing up then it is making progress and the chlorine is being eaten away. If you just follow the directions on the test kit you should be good to go. The FC test is one of the easier test to do and get right. Use a 10 ml sample, put in a heaping scoop of the powder and then use the R-0871 and one drop at a time swiring in between each one. Once the water turns pink to clear multiple your drops times .5 and that is your FC. Then use the R003 and put in 5 drops, if it stays clear your CC is 0. If it changes back to pink, put in enough drops of R-0871 to turn it back clear, multiply this by .5 and that is your CC. FC+CC=TC.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Mar 2009
    eastern washington state
    275
    I know I am going to get a bunch of slack for the way i do it....But i take the skimmer basket out and I pour it very slowly in the Skimmer.
    live in eastern washington state
    18x36, Vinyl inground 24k
    Hayward 1 hp filter pump
    1 skimmer/2 returns
    24" sand filter, polaris 280 with booster pump.
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by hayfarmer
    I have read on here that you can do it that way as well, but just not the most common way.
    Feb 2008
    Denton, TX
    5,061
    You can certainly do that, yes. The reason that we don't typically advocate for doing that is because we don't want others to think that you can do that with just anything. There are some chemicals that it would be a big no-no to do that (see muriatic acid).
    Mar 2009
    275
    Yes i would never put MA in the skimmer.. The reason i do it is because I usally have the solar cover on when i need to add bleach and its hard to hold it back and pour. The skimmer is just to handy for adding Bleach only.
    1 skimmer/2 returns
    May 2009
    Jasper, TN
    249
    Quote Originally Posted by 257WbyMag
    Please explain why.
    24' x 52" AGP = 13.5k gallons
    Dynamo 2.0 HP pump,Sand Dollar sand filter
    Polaris 65 vacuum (good when there are a ton of leaves on bottom), Pool Rover Jr. (LOVE it, but power box dead right now), AquaCritter (an excellent suction side cleaner)
    May 2009
    Jasper, TN
    249
    Quote Originally Posted by waste
    If you literally do ruin a LOT of pants that way, then why? Do you get free clothes?
    Mar 2009
    275
    some chems are very hard on the seals of the pump. thats why they say not to put some chems in you skimmer.
    1 skimmer/2 returns
    Jan 2009
    Cupertino, CA
    1,966
    Muriatic has a pH of around -1 (negative 1) and you really don't want a seriously low pH inside the guts of your pump/filter. I suppose you could drip it into the skimmer basket, but I think anything that qualifies as "pour" would be too much.
    --paulr
    BBB "Intermediate Swimmer"
    Jan 2009
    Cupertino, CA
    1,966
    Quote Originally Posted by rastoma
    Maybe that's why he calls himself "waste"??
    Apr 2009
    Central Minnesota
    74
    I have always added dichlor and poured bleach right into the skimmer. The chlorine quickly goes through the pump, through the heater, and back into the return jets. Never had a problem with any of the components. (I learned my lesson to NEVER do this with acid) Now that I am getting a new heater with a cupric-nickel heat exchanger, I am wondering if I should change my ways of adding chlorine. Is concentrated chlorine for a short period going through a cupric-nickel heat exchanger bad?
    18' X 36' X 4.5' vinyl oval in-ground 17K gallons, 250K BTU Pentair Master Temp NG heater, 1HP Hayward Super Pump, Hayward S200 sand filter, Hayward Pool Vac, Extreme mesh safety cover, TF-100 test kit.
    Mar 2007
    4,160
    TIME = $
    I open at least 6 pools each day (and my work week is Mon. - Sat.) so I'm perimeter dumping at least 12 gal. of 12.5% every day. With the splash that Richard spoke of and wind, the bottom 6" of my jeans get pretty threadbare within a couple months. This also doesn't take into account unnoticed spillage in the back of my service van that I kneel in nor, the occasional inadvertent leaking jug that coats me.
    I'm just a little different than most members here, I open and close 400+ pools every year and service twice that many - it gives me a knowledge/ experience base that the owner of 1 pool doesn't have - and I've never owned a pool
    Luv& Luk
    -Ted
  20. Back To Top    #20
    Always wear eye protection when pouring bleach.
    15,000 gallon unpainted plaster. Sand filter. Polaris 380.
