Results 1 to 7 of 7
Thread: Aquarite -- cheap cap to fit cell for cleaning
    May 2009
    St. Louis, MO
    45
    Has anyone found a cheap cap to fit the Aquarite cell, for cleaning purposes? I see a cleaning stand sold on line for $30 or $40. I was hoping to get a simple PVC screw-on cap at Home Depot. However, it is an odd size -- its not 1.5 inch or 2 inch. I can't find anything that fits it. Does anyone have a way to plug the cell at one end, so you can fill it with muratic solution for cleaning? I've tried the rubber plugs that I use to close the returns for winter, but they don't fit tight due to some ridges in the mouth of the cell.
    30,000 galllon, inground, vinyl liner, L-shaped pool
    1.5 hp pump, sand filter, heater, run pump 24/7
    Aquarite salt system
    St. Louis, MO, USA
    Ft Lauderdale, Florida
    1,455
    Re: Aquarite -- cheap cap to fit cell for cleaning
    Get a union from hayward that matches the cell union, then plumb to a 2" cap.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    571
    I use a #11 expandable rubber plug I bought it at Leslie's last year and it fit the end of my cell perfectly.
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    Mar 2010
    Mobile, Alabama
    34
    Knightcap, I had been considering looking for a cheap cap, too. Didn't realize the cell was not 1.5" or 2". Could you sand those ridges and help make the rubber plug work? I assume they are just the two seams from the construction of the cell?
    16x32 IG vinyl liner, ~19K gallon, built with my own blood, sweat, & tears!
    1 hp Water Ace pump, Goldline Aqua-Rite 40K SWG
    300# Hayward sand filter, dual skimmers, pool open 12 mos/yr
    May 2009
    St. Louis, MO
    45
    Mickey -- I have not been able to get a rubber plug to make a watertight seal, due to some ridges on the inside of the cell. Does your cell have these ridges?
    Poolcat -- no, the ridges are not seams from the manufacturing process. They look like they are supposed to be there, although I doubt there would be any harm done by sanding them away. I hate to sand the inside of my cell just yet, if there is another solution.
    St. Louis, MO, USA
    May 2009
    St. Louis, MO
    45
    This may be the conclusion for this thread. I tried a number 11 rubber plug in the salt cell last night, and filled it with water, and it held tight with no leaks, even with the ridge in the opening. The trick is to screw down the wing nut pretty tight -- the nut on the rubber plug. This seems to really expand the rubber plug and fill the gaps. So I think the cheap way to clean your cell is to plug it with a number 11 plug, screw the nut down tight, and fill with acid solution. No need for a $35 T-Cell stand!
    Thanks everyone!
    St. Louis, MO, USA
    Mar 2010
    Mobile, Alabama
    34
    Thank you, Knightcap. I'll have to get my own #11 plug now. Mine is really overdue for cleaning. I like cheap solutions. If washers cost 6 cents each, I bore holes in nickels!
