Thread: Tablets Without Acid
    Why does a tablet without acid not exist? From what I've read in Pool School and in these forums, the major drawback of the "pucks" is the acid they continually add to the pool. I hate that I have a an automatic feeder that I'm not using. Or maybe they do exist, and there is another reason not to use them?
    Alan
    IG
    Fiberglass
    Sand Filter
    17,500 Gallons
    Apr 2010
    South Jersey
    32
    Re: Tablets Without Acid
    I'm just guessing here but I assume they cannot just form pucks out of NaClO, it needs an additive to form a solid.
    ~20,000 gallon IG plaster pool
    myBluePool SWG, Nautilus NS48 DE filter
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Yep, there must be a binding agent.
    As an aside, this question gets asked often - shouldn't there be a blurb about the why's in the How to Chlorinate your pool section? We talk about what each product does, but nowhere do we explain why these are our only choices. Just musing...
    Mar 2007
    San Rafael, CA USA
    12,082
    The limitations are due to the chemistry.
    The Cyanuric Acid (CYA) in Trichlor (i.e. stabilized chlorine pucks/tabs) is not a separately added binding agent. The chlorine is attached to the CYA as a unique chemical compound -- one that is a solid that when formed with high pressure tends to stick together and slowly dissolve in water.
    Dichlor (i.e. stabilized chlorinating granules though sometimes that is crushed Trichlor) is also a solid, but is powdered or granular and dissolves much more rapidly in water. Both Trichlor and Dichlor increase the CYA level.
    Calcium Hypochlorite (i.e. Cal-Hypo) is also a solid and can be compressed into pucks, but doesn't stay together well in water so extra binders are added. Even so, it still tends to fall apart as it gets smaller and the binders can leave a bit of a mess. Special chlorinators are needed for Cal-Hypo pucks that are different than Trichlor feeders. Generally, Cal-Hypo is added as a powder since the pucks are so messy.
    Lithium hypochlorite is also a solid, but it dissolves too quickly in water to form pucks/tabs and it's very expensive.
    Sodium hypochlorite (i.e. chlorinating liquid or bleach) is put in water so is a liquid and at very high concentrations becomes unstable which is why you don't generally see chlorinating liquid above 15% nor see any "solid" sodium hypochlorite.
    Chlorine gas is obviously a gas and is toxic and dangerous to handle unless you are a professional so this is not used in residential pools except by a few pool services.
    So it just works out from the chemistry that there is nothing chlorine can be attached to chemically that would 1) be in solid form and 2) slowly dissolve in water and 3) not add anything you don't want. Since Trichlor and Dichlor increase CYA and Cal-Hypo increases Calcium Hardness (CH), the choices with the least side effects are lithium hypochlorite, sodium hypochlorite and chlorine gas. However, lithium hypochlorite is very expensive and chlorine gas is too dangerous so that just leaves sodium hypochlorite. This is a good choice as it is also close to pH neutral over time (i.e. when accounting for the acidity of chlorine consumption/usage) and its only side effect is to increase salt levels more than some of the other chlorine choices, but salt is far more innocuous than high levels of CYA or CH.
    There are options for automation of adding chlorinating liquid or bleach including The Liquidator and peristaltic pumps. Of course, there is also on-site chlorine generation using a saltwater chlorine generator (SWG).
    Richard
    Great summary, Richard.
    Thanks.
    MK
    13500 gal in ground. 1.5 HP Hayward pump. Triton Sand Filter. TFP and Pool Calculator. LQ C-201.
