Results 1 to 8 of 8
Thread: CYA High
    St. Louis, Mo.
    16
    CYA High
    My CYA is at 100. The pool calculator says to replace 60% of my pool water to get at a 40 reading. I have a 14,000g fiberglass pool that I have never drained before, except for your basic backwash. Do I drain all at once or a little at a time? Will the pressure from draining all at once crack the fiberglass. Or should I drain it 40% to get a reading of 60?
    Grecian/W a Step style,14ft by 30ft
    14,000 gallon,Fiberglass,
    Sand Filter
    Deepend 5ft
    Method(BBB)
    22,550
    Re: CYA High
    Since most CYA tests only read to 100 and report anything higher as 100, yours could be higher than that. In St. Louis and with a fiberglass pool I wouldn't drain more than a third of your water at one time. You may have to do several drain/fills to get the CYA down.
    St. Louis, Mo.
    16
    Re: CYA High
    Thanks for the reply. Everything else is pretty good. my water is very clear. So should I concentrate on not adding other chemicals until i get my CYA right?
    Sand Filter
    Deepend 5ft
    Method(BBB)
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: CYA High
    You'll want to make sure to keep chlorine in it so it doesn't turn green. It may take a while to do multiple partial drains, and you don't want to get algae during that time!
    St. Louis, Mo.
    16
    Re: CYA High
    This is probally a silly question. should set my pump at 6 o'clock until the water gets below the skimmer and then set to 9 o'clock so it only drains from the bottom. I feel retarded asking but I never done this before? Or would that be too much draining at one time.
    Brett
    Sand Filter
    Deepend 5ft
    Method(BBB)
    Oct 2009
    3,899
    Re: CYA High
    Just set it to only drain from the bottom. Otherwise you'll suck air and lose prime as soon as the water level gets below the skimmer.
    22,550
    Re: CYA High
    Sounds like you ahve a 3-way valve to select between the skimmer and the Main Drain. I'd set it to pull from the main drain during the whole time I was lowering the water level.
    MITS -- GMTA
    St. Louis, Mo.
    16
    Re: CYA High
    I will start doing this today when I get home from work. I do have a 3-way valve. Thanks alot for all your help.
    Brett
    Sand Filter
    Deepend 5ft
    Method(BBB)
