Page 1 of 15 123411 ... LastLast
Results 1 to 20 of 294
Thread: Post a picture of yourself
    Mar 2010
    Spring, TX
    1,082
    I have found this fun on other sites and it helps put a face with a name. I will start. Had a presentation for school.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Feb 2008
    Denton, TX
    5,061
    Re: Post a picture of yourself
    Aw shucks...do we have to?
    I'll only put mine up if Butterfly and duraleigh BOTH do it.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    I've seen some creative posts in some of these kinds of threads. Backs of heads, sillouetes, shadows, etc. Mine on one parrot board I belong to has me standing with my Macaw in front of my face with his wings spread out - I'm there, just a bit "obscured" -
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Sounds like everyone's scared.
    I just did this yesterday...DW, myself, and someone who hated his job.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by 257WbyMag
    hee hee!
    You're done SLAMing when:
    Mar 2010
    Spring, TX
    1,082
    Why is everyone scared except for melt in the sun. BTW, melt which one are you?
    Oct 2009
    3,899
    Unfortunately, neither the pretty one on the left nor the one who got paid to dress up like Aladdin.
    Two of me, because I'm vain.
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
    jmack1159's Avatar
    Apr 2010
    Arkansas
    45
    Ok i am game
    24' Above Ground installed March, 2010
    22 Sand Filter With Zeolite
    1.5 HP Motor Pump
    Successfully using the BBB Method!
    pool-school
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Don't hold your breath for a picture by the pool, all the prior years nobody would dare take a pix of me there and so far this year I would just look crabby anyway. This is mostly what I am doing in 90% my free time when not working on pool stuff so I can actually swim- pic from last fall at our local parade with my pride and joy, Shadow.
    Aug 2009
    North Central Texas
    1,358
    GeekGranny mucky pool cleanup and acid wash 2004. The plaster under the scale is blue. Last picture is summer 2008 acid wash after we let the tadpoles become frogs and escape. Temp that day was 100+ F. Not much cooler at night. My visiting friend, Shelsey, helped me. Geekgranny does have some experience with calcium scale. And metal stains. This was before discovering TPF. Shouldn't ever see these conditions again.
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Butterfly's Avatar
    South Carolina
    10,045
    Here's Butterfly with her Pool Boy
    Mar 2010
    Spring, TX
    1,082
    See how much fun this is?
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by mynewpool
    heh, heh, I'm waiting on 257 and duraleigh
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    Here I am...on the right.
    [Edit - clarified which one ins me]
    20'x40' / 30,000 Gal / In Ground / Vinyl
    Pentair FNS 48 DE Filter / Pentair Challenger 1.5 HP Pump
    Jandy Lite2 400k BTU Propane Heater / Dolphin Dynamic cleaning robot
    TF-100 Test Kit / BBB
    Creator of SimplePool (BBB Friendly Android App) http://www.simplepool.net
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Here's me.
    People say I look like someone famous, but I don't see it...do you?
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Mar 2010
    Spring, TX
    1,082
    Mike is the new Brad Pitt.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    No Mike, I don't see it either. You are much better looking than BP
  20. Back To Top    #20
    FinsUp's Avatar
    Jul 2009
    Michigan
    68
    Way to go Mike, you just killed the thread. Now what guy is going to post a picture of himself after you posted yours! I mean, really, sheeesh.
    32.6K Gallon 16x41x24 L-Shape Vinyl Inground by Fort Wayne Pools
    DE Filter, 1HP Pump, Sta-Rite 400,000 Btu Propane Heater, Pentair IC40 SWG
    One Wife - Three Kids - Two Dogs
