Thread: TF100 solutions shelf life
    Apr 2009
    Lancaster, pa
    71
    Was just wondering..I purchased a TF100 kit at the beginning of last season...how long can you keep the solutions before they "expire"..I actually won the extra kit last season in the contest, and didn't even open it yet!! Those solutions were'nt even opened yet! Just want to make sure I'm using "good" solutions!!
    Thanks
    Curt
    PS..also need to know about the DPD powder..how long that is good?
    24' AGP (13,600 gal)
    Sand Filter with 1.5hp pump
    Lancaster, PA
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: TF100 solutions shelf life
    If sealed and not opened, everything should be good for at least 2 years, though Taylor officially says to replace reagents annually. The most sensitive reagents are the indicator dyes and the FAS-DPD titrating reagent, but if sealed and in the dark and kept cool they should be good for 2 years. The DPD powder should be fine if kept sealed -- moisture and oxygen are its enemy.
