Thread: Shelf Life
    Shelf Life
    What is the shelf life for granular chemicals? I have some PH Minus that just doesnt seem to be taking in my pool.. could it be to old?
    Lori
    21,200 Gallon AG Sand Filter
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Shelf Life
    I doubt it. A much more likely possibility is that your pH is higher than your kit can read, and you can't tell exactly how high it is (ie. 8.2 looks the same as 9; a HUGE difference!).
    Re: Shelf Life
    Thank you, you were right. Went and checked this morning and it my PH is now down in the 7.5 area... from 8.2+
    Lori
