Page 1 of 4 1234 LastLast
Results 1 to 20 of 76
Thread: First Time, checking my figures
    Nov 2009
    Cleona, PA
    236
    Here is what I got this evening:
    Date 05/19/10
    FC 0.5
    CC 1.5
    TC 2
    pH 7.2
    T/A 180
    CH
    CYA 40
    Temp 60
    I'd like to shock, so I can get to a baseline quickly.
    My pump is up and running.
    My cover (black tarp-like pool cover) is on.
    Pool is starting to look a tad green.
    I've put 3 96oz jugs of cheap bleach (5.25%?) in sporadically since April.
    Should I tackle pH or FC first?
    I have 2 128oz jugs of 6% bleach ready to go, and the grocery store 1 mile away stocks it.
    I also have 3 1lb bags of SunGuard Multishock (Cal Hypo 47.6% and Sodium Tetraborate Pentahydrate 29.8%). I would like to use these up since I have them, if I can.
    Pool Calculator says
    3.2 jugs (128oz jugs) or 3lbs 7 oz of the Cal Hypo
    36oz of Borax
    On dry chemicals, should I get a large measuring cup that does ounces?
    13,500 Wilkes Vinyl AG (15'x30' rectangular)
    Hayward Power-Flo LX SP1580, 1HP
    Hayward S-160T High Rate Sand Filter
    Re: First Time, checking my figures
    your PH is just right for shocking and you should do that now. Go ahead with the bags of shock since that will take all of them and some bleach after to make shock level. Not sure about the question on the dry measure I normally weigh my dry chem's. Hold the shock level untill the CC is .5 or less then correct the PH. After that your TA is high use muratic acid and airate to offset the ph drop it will cause.
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    Don't worry about the PH. You didn't list your CH level. Cal-hypo adds calcium. Depending on what your current CH level is, that may or may not be a good idea. Chances are fairly good that using cal-hypo will be fine, but if it is easy to get a CH level first, that would be best.
    Cleaning things up should be relatively easy, because the water is fairly cold. Algae doesn't grow very well in the cold, so it is easier to kill.
    Nov 2009
    Cleona, PA
    236
    What's the best way to use the powdered Cal-Hypo, mix it in water in a bucket or just put it in the pool?
    The package normaly says to broadcast it around the pool dry, however I have done it both ways. I would follow the package directions.
    coloeb,
    I recommend pre-dissolving in a bucket of water and then pouring that slowly in front of a return jet with the pump running.
    Nov 2009
    Cleona, PA
    236
    Ok, I found I had 4 bags of the shock. I mixed it in 10 gallons of water (2 5 gallon pails) and slowly added it in front of the return. I did this this morning. I didn't have time to wait and check the levels after an hour, had to go to work. I'll try to check first thing when I get home. I'll be home all day tomorrow, so I may run out and get some more 6% bleach to maintain the shock till FC levels off.
    Next time I check, I'll do CH, but according to the strips, it was within range. I just didn't have time to check last night with the good kit.
    (I should be waiting till Friday, so I have time to do things right, but I'm too excited. )
    Nov 2009
    Cleona, PA
    236
    Ok... something's eating my chlorine...
    Today is going to be the day to kick this in the butt.
    Just did another test. (Second, didn't get to yesterday.)
    Date 05/21/10
    FC 1
    CC 4
    TC 6
    pH 7.2
    T/A 200
    CH 120
    CYA 65
    Temp 64
    So, something's eating my chlorine... I'm going to bring to shock level with bleach (since the SunGuard raised my CYA and I don't have any.) And I'll try to maintain it through the day.
    To lower TA you're supposed to lower pH and aerate. Nobody around to help take the cover off, how can I aerate... or can I wait on that.
    Feb 2008
    Denton, TX
    5,061
    Wait on your TA. Your pH is nice and low. Just shock your pool.
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    If you really want to kick this thing in the butt...put on some coffee and go into infant care mode. One or two sleepless nights this weekend will make a world of difference in progress. The night I made serious shocking progress it was 1030 pm and I went back out to walmart and got more bleach. I felt like I'd come too far to go to sleep. I kept at it through the night till about 1am, then I was up early to hit it again. Keep notes so you remember what you add. My husband thought I was nuts but that weekend we were blinded by the sparkliness!
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    Nov 2009
    Cleona, PA
    236
    Will do... just bought 3 182 oz jugs of bleach... and will get more as necessary.
    Found a rubbermaid water bottle at the store, with oz. gradients... I can use to fine tune. But for now it'll be jugs at a time.
    30,421
    You do not have enough chlorine....I would start with 8-10 large jugs. Skimping on the chlorine only prolongs the shock process.
    Butterfly's Avatar
    South Carolina
    10,045
    Yep, not enough chlorine on hand. Those three jugs will only bring your FC to about 20 (barely shock level for your CYA) assumming zero FC now. You prob should go ahead and get some more jugs just to avoid having to make extra trips. Better to have extra on hand rather than run out in the middle of a shock and the store be closed.
    PG22 is right that if you do this mostly at night and stay with it, you can get way ahead in a hurry! No sun in competition for the chlorine
    You're done SLAMing when:
    Nov 2009
    Cleona, PA
    236
    I didn't think there would be much sun consumption since the covers still on. I will get more chlorine. I already had some. $2.59 a jug at the store. I'm going to see if Lowe's has some liquid chlorine (12%).
    2 questions.
    My water is a little low, so I was going to fill for 30 minutes. Would that aerate a little to lower TA? (I know it's not a biggie right now, but just curious.)
    2nd if I'm only adding 6% bleach, do I need to check the CYA every hour? Or can I just test for TC/CC levels every hour to maintain shock levels?
    Nov 2009
    Cleona, PA
    236
    Ok, I tested, and got 3 FC and 8 CC. Didn't do CYA yet.
    Question 3) I was doing the FC test, and every time I got it clear (1st at 1, then at 2) I was going to add R-003 to do the CC test, but it started getting pink again. It stopped when I got to FC 3. Thoughts?
    The FC test will always turn pink again if you let it sit too long. Normally, when the CC level is very low, it won't turn pink again for a minute or two. But if the CC level is relatively high, it will turn pink again fairly quickly. You should have the sample turn completely clear for at least five seconds of swirling, and then move on to the CC portion of the test, even if it turns pink again after the five seconds are up.
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Quote Originally Posted by Butterfly
    I have an abbreviated knick name!!! I feel soooo special...
    Sorry to butt in.. it just made me giggle...
    Nov 2009
    Cleona, PA
    236
    Getting there...Last added chlorine (2.25 big jugs) @ 12:45 and just tested at 2:40
    Date 05/21/10
    Time 02:40 PM
    FC 8.5
    CC 3.5
    TC 12
    pH
    T/A
    CH
    CYA
    Temp 68
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Keep bumping it up...just keep bleaching just keep bleaching....
  20. Back To Top    #20
    Your shock level at 65 cya should be 19 ? might want to check that.
    coloeb,
